Roman
posted on 30/11/08 at 01:03 AM |
Wiring bike fuel pump
Is it possible for someone to guide me through wiring up a bike fuel pump or point me in the right direction for the information.
Thank you.
ReMan
posted on 30/11/08 at 01:12 AM |
Usually only 2 wires for carbs, switched with the ignition.
Roman
posted on 30/11/08 at 01:15 AM |
So just as simple as 1 wire to ground and 1 to position 2 on ignition switch?
blakep82
posted on 30/11/08 at 01:46 AM |
not wanting to hijack, but what about the facet pump? its got one black wire coming out.
is black live and the body earth? the body does have a spade connector on it
________________________
ReMan
posted on 30/11/08 at 10:02 AM |
Yes.
Almost certainly
[Edited on 30/11/08 by ReMan]
r1_pete
posted on 30/11/08 at 10:25 AM |
The facet pumps are body earthed, but but no spades, they use a short wire with two ring connectors which are used to bridge the rubber mounts.
[Edited on 30/11/08 by r1_pete]
