Author: Subject: c20xe mbe map
donn006
posted on 30/11/08 at 06:35 PM Reply With Quote
c20xe mbe map
hi anybody out there got a mbe 956 map for a c20xe running cream injectors and gsxr throttle boddies i can have a copy of
mggareth
posted on 5/12/08 at 10:44 PM Reply With Quote
hi are you running a coil pack or dizzy
i might have something close
NS Dev
posted on 8/12/08 at 12:20 PM Reply With Quote
yep but its a last resort as you'll have to plug into my laptop, as the usb doesn't work and nor does the disc drive!
NS Dev
posted on 8/12/08 at 12:22 PM Reply With Quote
hang on, isn't it you who already had the map off me donny?
donn006
posted on 9/12/08 at 10:49 PM Reply With Quote
mbe map
im running an external coil pack
donn006
posted on 9/12/08 at 10:54 PM Reply With Quote
mbe map
hi nat yes its me im useing loads of fuel with the your map and it keeps backfireing when cold and i think its becauce your useing jenvey t/b and im useing gsxr t/b im trying to get a map from someone who is running gsxr t/b to see if it is the map or something wrong with my ecu as still cant get temp setting down
