dan_g8
posted on 9/12/08 at 01:33 PM |
dif between left and right wheel bearings?
Hi, This is probably a really silly question but I am about to change the wheel bearings in my uprights. I called my local supplier and they said that
they only had left hand bearings. Is there a difference between left and right hand wheel bearing kits?
Dan
dave r
posted on 9/12/08 at 01:34 PM |
if its a kit i would assume it has a nylok nut with it
one will be lh, the other side rh thread
bearing should be the same
r1_pete
posted on 9/12/08 at 02:10 PM |
Are you using Ford stub axles? then they should be the same, as I recall the nuts are both RH thread secured with a split pin.
cd.thomson
posted on 9/12/08 at 02:56 PM |
I second Dave on this one, I've just bought someone too and its because the new hub nuts supplied have different handed thread.
posted on 9/12/08 at 06:28 PM |
What hub are you using? Sierra rear hubs have different nuts each side , IIRC the fronts have left or right hand threaded nuts accordingly . Some kits
for the Sierra come with both nuts .Cortina front bearing kits are not handed
Flamez
posted on 9/12/08 at 07:38 PM |
yeah sierra rear hubs have different threads. The aim is to tighten towards the front of the vehicle.
my build mac1motorsports
