Benzine
posted on 9/12/08 at 09:16 PM |
Bending metal/cone shape
I've just used Cone Layout to make a cone for the collector I'm making. I've traced it onto the metal and cut it but how do you go
about bending it?
It's similar to this but longer:
I've cut out out of 2mm steel (plentiful & all I have at the moment), is this too thick to start with? Seems very difficult, any ideas? Rest
of the exhaust parts are 1.5mm.
[Edited on 9/12/08 by Benzine]
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
RichardK
posted on 9/12/08 at 09:19 PM |
Would a stainless steel household funnel do the job? just thinking that all, and 2mm does seem a bit ott, more like 1mm as its strength will be
achieved when in shape me thinks.
Cheers Rich
Gallery updated 11/01/2011
posted on 9/12/08 at 09:22 PM |
Seems a bit thick to me!
Can you roll/form it around something - I'm thinking along the lines of the way Uncle Ron shows how to form the curves of an ally bonnet in THE
BOOK. Large bit of wood (log maybe), clamp one edge and start persuading it around.
Benzine
posted on 9/12/08 at 09:28 PM |
Yeah it does seem too thick. Humbug! Humbug!
Humbug, Mr Baldrick?
Need to get some thinner metal. I hate buying it, I can get some locally but only in huge sheets or I can get the right quantity online but have to
wait a few days
it moral.
Humbug
posted on 9/12/08 at 10:05 PM |
Yes, what do you want? ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Benzine
posted on 9/12/08 at 10:10 PM |
![](/images//smilies/tongue.gif)
it moral.
cryoman1965
posted on 9/12/08 at 10:18 PM |
2mm is thick without the correct tooling.
To form the cone you should draw a fan shape (lines close together) on the template and then gradually put a slight bend in each line. Slowly a
conical shape will appear.
Long process.
HTH
Nige
welderman
posted on 9/12/08 at 10:23 PM |
i could do it in 10mm stainless if you want, but not exactly locost or light weight.
If your struggling, could make one up in mildsteel and post it, let me know
Thank's, Joe
I don't stalk people
907
posted on 9/12/08 at 10:32 PM |
Hi Benzine,
I assume you don't have a brake press, folder or rollers.
Do you have a good vice, piece of thick wall pipe, (steel scaffold tube) and a hammer? Nylon mallet would be good.
Paul G
edit to say: If you U2U me a phone number I'll talk you through the technique.
(I can talk quicker than I can type)
[Edited on 9/12/08 by 907]
Volvorsport
posted on 9/12/08 at 10:37 PM |
you want a 16g cone rolled ?
i think a scaffold and a hammer , you would do it with that and maybe some gentle heat .
what inlet/outlet diameters ?
www.dbsmotorsport.co.uk
getting dirty under a bus
IDONTBELEIVEIT
posted on 9/12/08 at 10:53 PM |
a set of rollers with a piece of angle jammed in the right hand side with the smaller end of the cone touching this angle and just roll piece of
cake![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Are We There Yet, Are We There Yet!!!!
posted on 9/12/08 at 11:08 PM |
2mm is just making life very difficult for yourself. 16 gauge is about as thick as you'd need to be honest, and you can form that by hand by
gently bending it in radial lines over a piece of stout pipe held in your vice (e.g. bit of scaffold tube).
Simon
posted on 10/12/08 at 01:11 AM |
When I did the cones (four of them!!), I cut out the shape (16swg stainless) and made up a tool to go in a vice.
The tool consisted of a length of tube (about an inch in diameter) with a piece of plate welded at both ends with a gap underneath so cone shape could
be put under the plate and held in place while it was bent around the tube. Bent them by hand
Simon
Simon
posted on 10/12/08 at 01:22 AM |
Just done a quick "Sketchup" - picture speaks a thousand words, and all that
Simon
motorcycle_mayhem
posted on 10/12/08 at 11:01 AM |
I made a half-cone out of substantial sheet (for a Hillman Imp rear spring turret) , very neatly, by hammering (nylon/rubber/wood spacer) around a
heavy steel tube. Heavy steel tube in this case was a handy lamp-post outside my house..... dink dink...
Benzine
posted on 10/12/08 at 12:40 PM |
Thanks for the help ^__^ In the end I found some perfect metal - an old ammo crate I had lying around that used to be a PC case. I've cut the
cone shapes out and they're much easier to bend
it moral.
