cloudy
posted on 12/12/08 at 09:14 PM |
Best Tool to cut ally floor pan?
I need to cut my ally floor pan into a curved shape, whats the best tool to use?
James
www.warnercars.com
stuart_g
posted on 12/12/08 at 09:15 PM |
nibbler or jigsaw
Danozeman
posted on 12/12/08 at 09:21 PM |
Jigsaw with plenty of lube on the blade.
Or nibbler.
Dan
cloudy
I have a nibbler but it takes a bite of about 2mm each time, it'll take years!!! I think a jigsaw will just rip and distort the panel -
it's only 1mm
James
www.warnercars.com
philw
posted on 12/12/08 at 09:26 PM |
Plasma cutter!
Must try harder
Triton
posted on 12/12/08 at 09:27 PM |
Nibbler but will leave evil bits.
www.tritonraceseats.com
www.hairyhedgehog.com
jacko
posted on 12/12/08 at 09:29 PM |
Jig saw and spray the blade and alloy with WD40 or light oil
clairetoo
posted on 12/12/08 at 09:39 PM |
One of these ?
Well..........it's what I use at work
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 12/12/08 at 09:46 PM |
Hand nibbler - slow, but accurate and clean cutting.
Remember to oil the nibbler too.
posted on 12/12/08 at 09:58 PM |
1mm is easy to cut shears or snips --- tinsmiths snips, aviaton shears, air shear or bench shear or a bench wheel cutter.
BUT 1mm aluminium alloy sheet is way too thin for a floor --- without doing the maths a 2 mm floor would be about 6 times stiffer in
bending a still only half the weight of 1.5mm steel.
Black Cat
posted on 13/12/08 at 07:07 AM |
Its got to be a band saw, clean cut and ali is supported so no distortion.
big_wasa
posted on 13/12/08 at 09:01 AM |
Ive got the plasma, air niblers and jigsaw ect but by far the best tool for the job was a good set of tin snips ![](/images//smilies/smile.gif)
big_wasa
posted on 13/12/08 at 09:03 AM |
did you gat it pained in epoxy ? I am interested in your results.
Danozeman
posted on 13/12/08 at 09:08 AM |
for 1mm ally tin snips has to be the best easiest and quickest of all!! Make sure its a decent set.
Dan
RichardK
posted on 13/12/08 at 10:26 AM |
If you have a compressor then one of these air shears will do the job lovely.
Rich
Gallery updated 11/01/2011
TOO BADD
posted on 13/12/08 at 11:44 AM |
Cut all my ali with a stanley knife.... easy just score 2/3 times then wiggle it and snap. Nice clean cuts. You need a new blade as well.
Mark Allanson
posted on 13/12/08 at 03:01 PM |
Aviation snips, its what they are designed for, just regularly dip in parafin to give a really sharp cut.
I agree about the 1mm ally - only suitable for wrapping up a turkey
