afj
| posted on 14/12/08 at 07:07 PM |
r1 4-2-1 which way round
r1 2003 in an mk indy(not that it matters) does it matter which way the collecter goes on the 4-2-1 bit. at the mo ive got cylinder 1 and 4 going
into 1 and cylinder 2 and 3 going into 1 ... if that makes any sence, only asking as ive just got back froms eds and his is cylinder 1 and 2
going into 1 and 3 and 4 going into 1
blakep82
| posted on 14/12/08 at 07:12 PM |
depends on the firing order i guess. if its 1-3-4-2, then i guess its right, though i don't know anything about exhaust design
________________________
mark chandler
| posted on 14/12/08 at 08:40 PM |
1&4, 2&3 on my blade, I did look it up at the time when making it.
So it fires on the induction stroke on to'other, gases pulling more fuel in.
Yours is correct, 'eds' is easier to design and build but not right.
Regards Mark
afj
| posted on 14/12/08 at 08:49 PM |
thanks for the help
progers
| posted on 14/12/08 at 09:11 PM |
I can shed some light on this as I have tried it both ways (ooeer missus).
Initially i started out with 1&2, 3&4 pairing and it worked fine, producing around 133 RWHP on Powertechs rolling road after mapping. The
following season I did an experiment and changed the pairing (as some aftermarket exhausts have this paring) and achieved 136 RWHP after another
mapping session. Not a great deal of difference but an improvement.
The conclusion I draw is that either works OK and its more down to choosing correct primary and secondary lengths as much as anything, and getting
your engine correctly mapped on a rolling road.
Paul
multanen
| posted on 14/12/08 at 09:30 PM |
Akrapovic seems to use 1&2, 3&4. I bet they have tried both...
Finnish Locost-racer Markku tested two otherwise identical manifolds and 1&2, 3&4 produced 7 hp more + better torque at low rews.
So even though 1&4, 2&3 might be better in theory, I believe 1&2, 3&4 is better in practise.
eddbaz
| posted on 15/12/08 at 04:14 PM |
Al,you must be going blind with the excitement of nearly completing your build, my exhaust is 1-4 and 2-3.
afj
| posted on 15/12/08 at 04:29 PM |
ITS ALL THE EXCITEMENT
[Edited on 15/12/08 by afj]
