Author: Subject: air/fuel gauge
jedi
posted on 25/12/08 at 07:35 AM Reply With Quote
air/fuel gauge
hi all, whats the easiest/cheapest way of fitting an air/fuel gauge and lamda sensor, i have bike carbs and megajolt if that helps, cheers
will121
posted on 26/12/08 at 11:06 AM Reply With Quote
all i done was i got a what looked a home made fuel air meter of ebay( but havent seen another one like it since) it just has 4 LED's which iluminated at different voltage outputs from the Sensor, a 4 wire Lamba sensor and a weld in bung for the exhaust manifold wired it up all in £45 and works really good and set my motorbike carbs up with it, dont know what outer ebay meters are like and a wide band sensor and meter would always be better but mine works fine for what i needed and carb setup feels v good,
like this DIY one which also may be a locost option
DIY fuel/air meter
[Edited on 26/12/08 by will121]
posted on 26/12/08 at 03:19 PM Reply With Quote
A digital multi meter can be used with a lambda sensor as a very basic air/fuel ratio meter . Have a look at Dave Walkers book on engine management for details
