Author: Subject: shortened sierra driveshafts
rash
posted on 27/1/04 at 08:39 PM Reply With Quote
does anyone know how much to shorten the driveshafts for a "standard" book chassis
Stu16v
posted on 27/1/04 at 09:14 PM Reply With Quote
Difficult to say, because the measurements will depend on where the rear uprights (and from that, the flanges for the driveshafts) will be, which depends on your suspension design.
Rather than having the expense/hassle of having driveshafts shortened, why not have a rethink and use standard sized shafts?
JohnN
posted on 27/1/04 at 09:18 PM Reply With Quote
The Leugo Velocity XT is a standard book chassis, but uses a full size sierra rear end. They (Luego) therefore can supply the relevant wishbones etc to suit
John
rash
posted on 27/1/04 at 09:23 PM Reply With Quote
using dedion set up , tried shafts in diff to get an idea of what it would look like but they stick out way to wide ????
okey dokey
posted on 27/1/04 at 09:46 PM Reply With Quote
Easier to buy the axle because all that messing about bit has been done for you, unless you like all that messing about of course!
stephen_gusterson
posted on 27/1/04 at 10:45 PM Reply With Quote
i asked if luego shorten shafts - they offered to sell me a sleeve so i could shorten my own - about 20 quid i think
atb
steve
James
posted on 28/1/04 at 10:33 AM Reply With Quote
There's instructions on Rorty's site on how to do it too if you're interested!
http://home.iprimus.com.au/rorty/content/tech.htm
HTH,
James
stephen_gusterson
posted on 28/1/04 at 10:59 AM Reply With Quote
thanks!
Rorty posted that data on here about a year ago and I printed it out
atb
steve
James
posted on 28/1/04 at 12:19 PM Reply With Quote
I was providing it more for Rash than yourself Steve!
I know you're way past that stage!
James
stephen_gusterson
posted on 28/1/04 at 02:18 PM Reply With Quote
erm, actually - no! I got my shaft (oh er) cut and shut with an internal dowel. Once I saw Rorty's solution I decided a sleeve should be used too.
Im planning on getting one from Luego at some point soon and putting it on the existing shaft.
It works as is on the drive, but I wouldnt trust it if it was floored
atb
steve
rash
posted on 28/1/04 at 05:22 PM Reply With Quote
thanks james think ill follow rortys instructions
Alistair Mc
posted on 29/1/04 at 04:54 PM Reply With Quote
Im using standard sierra shafts, my car is plus 2" from book, there is quite a lot of movment in the cv jonts. As mentioned I guess it depends on yor upright location and weather you use negative offset wheels.
