Author: Subject: Modifying HT lead ends
andrewturner
posted on 10/1/09 at 08:43 PM Reply With Quote
Is it possible to modify HT leads and if so how?
thunderace
posted on 10/1/09 at 08:55 PM Reply With Quote
motorbike ones can be moded and there are things you can do with car use like add SPITFIRE MULTISPARK ect as seeb forsale on ebay.FLASHING SPARK PLUG CAPS ect .
[Edited on 10/1/09 by thunderace]
blakep82
posted on 10/1/09 at 09:16 PM Reply With Quote
didn't you mean like changine the ends on them for different coils and stuff?
[Edited on 10/1/09 by blakep82]
________________________
MakeEverything
posted on 10/1/09 at 09:43 PM Reply With Quote
not sure why youd want to "Modify" them?
I used to make them for a huge furnace where i worked once. We bought High Tension cable by the drum, and the ends and made them to length.
Kindest Regards,
Richard.
andrewturner
posted on 11/1/09 at 05:38 AM Reply With Quote
Yes I want to change the ends of on the plug side from Duratec to go into a Toyota
clairetoo
posted on 11/1/09 at 07:48 AM Reply With Quote
Since modern plug lead ends appear to be molded on , I dont think you will be able to remove/refit them - the custom lead set on my car (Mazda caps , Ford coil pack) cost more than the engine
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
posted on 11/1/09 at 12:18 PM Reply With Quote
i've got the same problem. vauxhall engine (twin cam, so its got those long plug leads) and ford coil pack. the vauxhall leads sort of fit the coil, but they're a bit wobbly, and don't seal well.
g.gilo
posted on 11/1/09 at 12:41 PM Reply With Quote
plug leads
hi folks
go to a good bike shop, ngk do a good selection of plug caps.
graham
