archspeed
posted on 15/1/09 at 08:38 PM |
Help - Fuel Line - How often does it need to be secured?
Hi All,
As per title really, I gather that for SVA the wiring has to be clipped every 30cm, Brake lines need to be "secure", but what about fuel
lines?
I've done a quick search and can't find it - Sorry If I have missed it..
Thanks as allways....
adithorp
posted on 15/1/09 at 08:52 PM |
Not stated for fuel (or brake) lines.
Stick with max of 300mm and you'll be fine.
adrian
http://jpsc.org.uk/forum/
archspeed
posted on 15/1/09 at 09:12 PM |
Thanks for the quick reply Adrian.
Kevin
mad-butcher
posted on 16/1/09 at 07:27 AM |
make sure the rubber fuel pipe is suitably marked a lot of test centres now require proof from manufacturer as to suitability, I thought it was daft
at first but thinking about it the tester is certifying your car as fit for the road if the fuel pipe splits cos you've used low pressure pipe
in a high pressure system and the car explodes technicaly he could be liable
