Kriss
| posted on 16/1/09 at 11:25 PM |
New 6 inch MK exhaust - how do i mount the bugger?
Went intot he garage today to fit my new can (cheers MK for a mega price, £165 delivered, which i think is better than the group by they offered!)
Anyways, appreciate I am going to need to cut the link pipe down to size at both end, but I am more concerned about fabricating a mount of some
sort.
As you can see from the pics the can has two little tabs weleded to it at (child language) 9 o'clock.
What would you imaginative guys do to knock up a mount. I do not want the can too close to the body work due to obvious reasons, which is also a
concern.
so, any ideas, suggestions or pics?
Obv the can will be a few inches lower as its on a couple of axel stands presently
PAUL FISHER
| posted on 17/1/09 at 12:28 AM |
MK use a fiesta engine mounting on there cars,and thats what I used on mine,you then need to bolt a piece of steel strip under the floor and the
bottom chassis rail,and bend it round to the bracket,then use the mounting rubber between them to hold it firm,they do not use the front mount,you can
cut this off,or just bend it in towards the link pipe,heres a example of the mounting you need.
http://cgi.ebay.co.uk/FORD-FIESTA-950-1-1-1-3-1-6-LOWER-ENGINE-MOUNTING_W0QQitemZ200297891651QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash
=item200297891651&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Also,before you fit it you can have it polished,or polish it yourself,they look alot better.
[Edited on 19/05/04 by PAUL FISHER].jpg)
eznfrank
| posted on 17/1/09 at 07:22 AM |
Just out of interest what was wrong with the old can??
bob tatt
| posted on 17/1/09 at 07:53 AM |
i would imagine it was too loud for track days
contaminated
| posted on 17/1/09 at 09:17 AM |
I used a stabiliser of a childs bike. Basically an L shaped bracket that bolts to the chassis under the car. It's got two little rubber exhaust
mounts between this and the can. Works really well and looks good. I have a spare if necessary.
A1
| posted on 17/1/09 at 03:19 PM |
i made up a bracket the bolted into the bottom rail, underneath the car, it bends and comes up the side. i made it so it can be taken away and you
dont see anything. for my 'loud' exhaust
marmot0
| posted on 17/1/09 at 03:34 PM |
If you use rubber exhaust bobbins they are designed to be compressed rather than shear
macca1
| posted on 18/1/09 at 07:27 PM |
What are your plans regarding a CAT,
I'm assuming you will need one?
Col
bob tatt
| posted on 18/1/09 at 08:14 PM |
hes on the road so no cat needed now .
Kriss
| posted on 18/1/09 at 08:30 PM |
right "all done"
had to firstly take about three inches off my link pipe. a sperate pipe between mani and the can.
then made an l shaped bracked bolted to the floor and to the rear exhaust mount.
problem i have no is the can seem to want to roll towards to ground so the outlet pipe is really low. no matter how much i bend or tighten in.
good news is the car is sooo much quieter. really happy with it overall as trackday noise will not be as much of an issue (at elast this should see
me on to a 105 day at brands lol)
