AdrianH
posted on 19/1/09 at 11:24 PM |
What other exhaust manifold would fit 1.8 CVH?
I am not even sure if any exist, but does anyone know if any other exhaust manifolds match up with the sierra 1.8 CVH engine?
Just looking at options as well as the original cast one with the engine.
Adrian
[Edited on 20-1-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
wrigglypig
posted on 19/1/09 at 11:44 PM |
Hi Adrian,
I too would be interested in a source of one of these as I am using the 1.8cvh ( see my piccies) I did see one for £200.00 in stainless I'll
look for the link. Send me a u2u if you find one. Kev
AdrianH
posted on 20/1/09 at 12:07 AM |
Hi Kev;
I believe it may be possible to use the existing manifold and part of the twin down pipe section, but could mean a sharp bend to come out at the
bottom of the side panel to have another bend to run down the car.
I am hoping some one may say yes a Zetec or a xxxxx fits the same, I just do not know enough on engines.
Adrian
mad4x4
posted on 20/1/09 at 07:39 AM |
There was a thread on here yesterday about Zetec Exhausts from EBAY / Robin HOOD. Think the KIT was £170 quid.
Scot's do it better in Kilts.
posted on 20/1/09 at 09:08 AM |
Both Ford Zetec and and Rover T series manifolds can be adpated.
However I have a puka Westfield CVH manifold at the back of the shed that might be 4 sale
whitestu
posted on 20/1/09 at 09:18 AM |
The only one that fiits without modification is from a 1.6 CVH. I put one one my Indy when I had the 1.8 cvh in.
The port spacing on the CVH is exactly the same as a Zetec, so with a bit of messing it should be possible to modify a Zetec exhaust to fit.
I now have the CVH exhaust on my 2.0 Zetec. All I did was to cut the manifold plate off a Focus non-cast manifold and weld the CVH maifold to it.
Stu
AdrianH
posted on 20/1/09 at 07:11 PM |
Thanks all for the information will store away for later use.
Adrian
