Author: Subject: fiesta 1.4 tdci help
zzr1100rick2
posted on 29/1/09 at 07:24 AM Reply With Quote
Hi we have a 04 plate 1.4 tdci fiesta and when its ticking over it makes a sound
like a petrol would if there was a loose plug ( chuffing ) have replaced the egr valve but is still the same performance is good its just noisy any sugestions
cheers Rick
Mr Whippy
posted on 29/1/09 at 07:32 AM Reply With Quote
blowing exhaust manifold? Can't you hear where abouts its coming from?
Agriv8
posted on 29/1/09 at 08:29 AM Reply With Quote
Just at cold or does it so when it warms up ?
cd.thomson
posted on 29/1/09 at 09:37 AM Reply With Quote
I'll swap it for mine?!
known problems:
heater, AC, horn and interior light and LHS electric window dont work (£200 spent so far on parts and labour to rewire the cars interior).
aux belt is chaffing/squeaking very loudly
the clutch, gear linkage and RHS wheel bearing have all gone in the last 2 months
oh theres also a squeak from the LHS door trim
oh and the cd player needs the Ford manufacturers code resetting
and a new brake pedal. AND theres a slight oil leak from the gearbox/engine mating surface.
[Edited on 29/1/09 by cd.thomson]
davidwag
posted on 29/1/09 at 09:54 AM Reply With Quote
Loose injector ? Causing blow past
jonesier1
posted on 29/1/09 at 10:35 AM Reply With Quote
tdci
injector seals, replace them all at the same time,there will prob be load of black crap around them,advise fitting new leak off pipes at same time.common prob
posted on 29/1/09 at 10:40 AM Reply With Quote
Fire rings.
or injector seals as Jonesy says common problem usually stinks of diesel under the bonnet as well.
zzr1100rick2
posted on 29/1/09 at 04:29 PM Reply With Quote
Thanks for the advice sounds like injector seals it is altho it does get better the more revs you have will have to investigate further cheers Rick
