Author: Subject: Throttle body trumpets/velocity stacks
phoenix70
posted on 30/1/09 at 12:43 PM Reply With Quote
Hi All,
I've got a set of throttle bodies I'm putting on my Pinto, but I need a set of trumpets for them, any ideas where I can sources these?
Scott
Mr Whippy
posted on 30/1/09 at 12:54 PM Reply With Quote
supplier linky
another linky
[Edited on 30/1/09 by Mr Whippy]
cd.thomson
posted on 30/1/09 at 01:00 PM Reply With Quote
Actually being useful Mr Whippy !
Generally the trumpets can be used from the original airbox, they just flex out. Thats what I'm doing with my R1s, theres no real need for the stainless ones from all the build diarys I've read.
Craig
Mr Whippy
posted on 30/1/09 at 01:08 PM Reply With Quote
hey I'm always being useful
phoenix70
posted on 30/1/09 at 01:22 PM Reply With Quote
I would prefer just to use the originals from the airbox, but I don't have it (unless someone does have GPZ1100 airbox kicking around)
Scott
phoenix70
posted on 30/1/09 at 04:43 PM Reply With Quote
Whippy,
Thanks for the links, but this is meant to be LOcost builders site, £200 for a set of trumpets, surely there is a cheaper option than that.
Scott
A1
posted on 30/1/09 at 06:14 PM Reply With Quote
K&N do some rather sexy individual cone filters...not exactly very trumpety but the induction noise is louder than the engine when you floor it
flak monkey
posted on 30/1/09 at 06:28 PM Reply With Quote
Standard 45 dcoe ones will fit if the flange on the tbs is about 47mm, just connect them on with some silicone hose.
Sera
http://www.motosera.com
omega 24 v6
posted on 30/1/09 at 06:35 PM Reply With Quote
Hi scott hows it going??
Try these for ideasMerlin motorsport
ormerlin 2
or
merlin 3
Numb nuts
posted on 2/2/09 at 07:10 PM Reply With Quote
I put a set of R6 bodies on my 1.8 Zetec and used a set of 'long' trumpets as used on the R6 (they have two short/two long trumpets).
It runs well, the best thing was they were really cheap new, from a Yamaha dealer
Just a few pounds each
phoenix70
posted on 3/2/09 at 03:58 PM Reply With Quote
Any chance you could tell me the inner diameter of the trumpets?
Ta
Scott
Numb nuts
posted on 3/2/09 at 08:31 PM Reply With Quote
The R6 trumpets are 42 mm I/D and 45 mm long
Cheers Steve
