Author: Subject: Ball Bearings Online?
alistairolsen
posted on 31/1/09 at 08:42 PM Reply With Quote
I need a cheapish bearing to use as a spigot bearing in a conversion.
12mm bore, 10mm thick, 35mm Outside Diameter.
Cheapest I can find is £18 plus vat and deal which is tantamount to robbery!
Anyone know of anywhere good to try?
flibble
posted on 31/1/09 at 09:02 PM Reply With Quote
worth a look
http://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=0&sort=2a&search_3fields=1&term1=12&term2=35&ter m3=10&x=44&y=3
Edit: scratch that, I didn't read the results properly, not too good afterall Sorry!
[Edited on 31/1/09 by flibble]
alistairolsen
posted on 31/1/09 at 09:28 PM Reply With Quote
I did the same thing, ooooh 4.50 to find that thats just the seal and the bearing was 18 quid lol.
Cheers for trying!
ashg
posted on 1/2/09 at 08:30 AM Reply With Quote
^^^^ what he said.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
nludkin
posted on 1/2/09 at 09:03 AM Reply With Quote
You could have a look at Bearing Boys. They seem a little cheaper than other places I have looked.
Schrodinger
posted on 1/2/09 at 11:57 AM Reply With Quote
You could try turning up a brass bush instead of a roller bearing.
Keith
Aviemore
alistairolsen
posted on 1/2/09 at 08:26 PM Reply With Quote
a 6202 is 11 mm wide unfortunately.
Id prefer a bearing to a bush
In the end I found a 6003 which i 35mm od, 17mm id and 10mm thick so I got one of those from ebay for 1.59 delivered.
