jedi
posted on 1/2/09 at 09:21 AM |
bike carb setup
ive got my bike carbs setup quite well now with a nice plug colour etc, but when you blip the throttle the revs dont quite settle as quick as i would
like, would it be a case of just putting stronger springs in the slides, or some other type of carb modification. zx6r carbs by the way cheers
tony
ReMan
posted on 1/2/09 at 09:34 AM |
You probably need an extra return spring on the throtte mechanism , due to the extra weight and resistance of the pedal set up over the bike
twistgrip.
How this is achieved depends on the carbs but can either be a straight spring to assist the existing return, or another small cable on the return
cable side with it's own spring.
I cant post a pic ath the moment but I hope you get what I mean
Dont touch the slide springs though.
Andy B
posted on 1/2/09 at 11:33 AM |
carb set up
Another thing to check is the carb balance or synchronisation. If one or more of the bank is out this will cause the revs to drop much slower as the
throttles do not all close in unison. It normally gives the run down a very lazy feel instead of the sharp snap you are looking for. It also affects
throttle response quite alot so worth a check
regards
jedi
posted on 1/2/09 at 01:23 PM |
cheers for the replys ive balanced all the carbs and everything seems to be spot ill try adding an extra spring next and see how i get on
