phoenix70
posted on 3/2/09 at 03:42 PM |
Throttle body trumpets
Hi Guys,
I'm on the lookout for some TB trumpets, the need to fit a 40mm O/D Throttle Body.
Oh and I need 4 for them
TIA
Scott
cd.thomson
posted on 3/2/09 at 03:51 PM |
still struggling to get some sensibly priced ones phoenix?
what bike are they from again? Ill keep my eye on ebay for you.
Craig
posted on 3/2/09 at 03:52 PM |
Ooooh! So do I!! If all else fails I might end up fabbing some out of GRP... Turn some floral foam on a pillar drill to the required profile and use
it as a buck to make some trumpets....
phoenix70
posted on 3/2/09 at 03:57 PM |
Yup still struggling, being a cheapscate, I really don't want to spend £100-200 on then, also there going in an airbox so I don't really
need shiney ones, just some plain old plastic ones will do. The TB's are off a Kawasaki GPZ1100.
Scott
[Edited on 3/2/09 by phoenix70]
liam.mccaffrey
posted on 3/2/09 at 04:00 PM |
once i get up and running in the workshop, im going to start making these because it seem like everyone want them
Build Blog
Build Photo Album
posted on 3/2/09 at 04:03 PM |
I could do with some longer ones as well for my 55mm jobbies![](/images//smilies/bigsmile.gif)
cd.thomson
posted on 3/2/09 at 04:07 PM |
My 55mm jobbie
*Rolls eyes* put it away coozer
Craig
twybrow
posted on 3/2/09 at 04:11 PM |
Are they not available from the OEM? I am using a Triumph engine, and the rubber inlet trumpets are £6 each from Triumph...
will121
posted on 3/2/09 at 04:19 PM |
Scott
as above can you not get a airbox off ebay which has the trumpets fitted? generally they are soft rubber type and just pull out of the origional hard
plastic air box.
cd.thomson
posted on 3/2/09 at 04:36 PM |
The GPZ1100 airboxes dont come up often unfortunately.
Craig
twybrow
posted on 3/2/09 at 04:41 PM |
Have you actually asked Suzuki spare parts? They will probably be a cheap spare part if they are still available.
clairetoo
posted on 3/2/09 at 05:06 PM |
This is what I made when I first went for throttle bodies - they are 40mm internally , but I can only find three `leftover's` the same - they are
allso quite long (110mm) as they were for a very short manifold setup .
I dont have any carbon , but I could knock up a set in aluminised glass fibre cloth ? (like the odd one on the right)
![](/galpreviews/trumpets 002.jpg) ![Crossflow bits](/gallery/trumpets 002.jpg) Crossflow bits
Or.........if others are likely to want the same , I could turn a former to whatever size needed ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 3/2/09 at 05:12 PM |
Thats kind of what I'm planning on doing but with a very shallow trumpet (not much height in the airbox) and a stepped bit so that they slide on
to the end of the 40mm tube as it enters the airbox without an internal restriction or ridge....
My plan of attack is
Floral foam
Pillar drill roughly file to shape (IE attack with dremel with sanding drum)
Car body filler
Smooth on pillar drill with files / sand paper
Wax
PVA
4 epoxy GRP trumpets....
I was going to make some moulds out of wax and then melt out the wax afterwards (I even made a little wax lathe to turn them on) but realised it was
much easier to make a buck....
phoenix70
posted on 3/2/09 at 06:00 PM |
I like those trumpets, unfortunately, they are too long, I would need them to be much shorter than that.
Scott
posted on 3/2/09 at 06:23 PM |
Get the saw out then
stevebubs
posted on 3/2/09 at 06:35 PM |
hint: look at the bike airboxes on ebay. They often have the rubbers attached...
stevebubs
posted on 3/2/09 at 06:38 PM |
e.g. this CBR600 box has 3 of the 4 still attached...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270149034537
chrisg
posted on 3/2/09 at 06:42 PM |
Imagine this, upside down with the "egg" bit removed
Might look a lot like a stainless steel trumpet......?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stevebubs
posted on 3/2/09 at 06:50 PM |
Clicky
<---- I used a 48mm bare aluminium spinnings on mine and connected them using jubilee clips and fuel filler pipe .... don't seem to do 40mm,
though
[Edited on 3/2/09 by stevebubs]
v8kid
posted on 3/2/09 at 08:35 PM |
Ian Richardson from Wildcat Engineering www.roverv8engine.co.uk supplied mine at a very reasonable price - give him a ring he's a good guy.
Numb nuts
posted on 3/2/09 at 08:45 PM |
Scot
The R6 ones are 45 mm long and 42 mm I/D in black rubber, will reduce to 40 mm with ease...and cheap ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
