Author: Subject: Help!!!
CraigJ
posted on 3/2/09 at 06:14 PM Reply With Quote
Help!!!
the top and bottom engine mounting bolts are stuck solid. there are no threads holding them just 20 years of crap. I have done the most obvious thing and hit them with a big hammer but it didnt even budge them. I have no soaked them in wd40 and going to leave them over night. Any advice how to get them out would be great.
omega0684
posted on 3/2/09 at 06:16 PM Reply With Quote
soak them in vinegar, the acid will eat away all the crap!
Paul TigerB6
posted on 3/2/09 at 06:18 PM Reply With Quote
Have you tried heat yet?? Try heating the metal of the engine block rather than the bolt before giving it a decent whack.
I guess on the bottom one, you could always try a spacer and then nut on the threads, and keep tightening it to try and pull it through
wrigglypig
posted on 3/2/09 at 06:20 PM Reply With Quote
Hi Craig, the method I have used with steel bolts stuck in Ali is to repeatedly use kettles of boiling water, you can also try repeated light taps ( and I mean taps ) on the end of the bolt as long as it is not held by the threads any longer. Let uss know how you get on
Kev
Mr Whippy
posted on 3/2/09 at 06:22 PM Reply With Quote
agreed this would be the safest method, I'd buy a plastic container and sit the engine in it. Fill with cheap vinegar and leave for a few days
posted on 3/2/09 at 06:31 PM Reply With Quote
There are better penetrating oils than WD40 (bit general purpose in my book). Serial applications of that should work (the oil will soak into the crud).... Apply something like Plus Gas daily for a week then give it a wack....
CraigJ
didnt think of the vinegar, will give it a try.
tomgregory2000
posted on 3/2/09 at 06:33 PM Reply With Quote
heat gets my vote, dig out the blowtorch it will work a treat
mark chandler
posted on 3/2/09 at 06:47 PM Reply With Quote
Definately heat, not the bolt but the ali lugs. No need to be afraid, its an engine block a blow torch will not damage anything.
carpmart
posted on 3/2/09 at 07:19 PM Reply With Quote
Another vote for heat! Will definately work!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
zzr1100rick2
posted on 3/2/09 at 07:42 PM Reply With Quote
Careful with the heat its an alloy bike engine isnt it ?
Daddylonglegs
posted on 3/2/09 at 09:58 PM Reply With Quote
Amen to the heat
But ditto for being careful with it
posted on 3/2/09 at 10:07 PM Reply With Quote
I would be reluctant to use heat on an ally casting. IIRC Loctite do a penetrating fluid that freezes the part that it is sprayed on .Might be worth using it on the bolt? Hammering may well damage the casing, as a last resort it may be worth cutting off the exposed bolt and drilling the remains out, it would take longer but shouldn't damage anything other than the bolt.
carpmart
posted on 4/2/09 at 07:23 AM Reply With Quote
Why would you be reluctant to use heat on an aluminum casing?
'94 MX5 MK1, 1.8
posted on 4/2/09 at 10:34 AM Reply With Quote
Heat them up, get hold of the unthreaded part with the mole grips and try to turn them. That's what they do at the bike shop. Plumbing torch temperatures will not hurt the aluminium you're more likely to damage it hitting it with the hammer.
