New Topic New Reply
Author: Subject: WIDE Chassis
ALEXARAS
posted on 7/2/09 at 10:39 AM Reply With Quote
WIDE Chassis
I am sorry if there is another topic, i just could not find it.
I have a Locost based on book (ron champion) and i am considering building a new one with a wider (sv chassis) planning to use E30 325 as a donnor car.
Are there any designs for a locost wide chassis? As i am only aware of ron champion design.
regards
Alex
[Edited on 2/8/2009 by ALEXARAS]
Locost 7 RS2000
Beach Buggy Rotary
zilspeed
posted on 7/2/09 at 10:45 AM Reply With Quote
regards
Alex
Try here
http://mcsorley.net/locost/
There are wide plans and other variations.
l0rd
posted on 7/2/09 at 10:46 AM Reply With Quote
the Mcsorley design?
basen on ron champion chassis with an extra two variations of
+4 longer
+442 longer wider taller.
iank
posted on 7/2/09 at 10:48 AM Reply With Quote
The McSorley plans are corrected champion chassis plans with a number of options on wider/higher/longer changes.
http://www.mcsorley.net/locost/drawings.htm
The newer ChrisG Sierra version of the book is certainly wider than the old Mk2 Escort version. No idea if it will take an E30 engine.
Edit: MUST TYPE FASTER!!
[Edited on 7/2/09 by iank]
Anonymous
James
posted on 7/2/09 at 10:58 AM Reply With Quote
Alex
Out of interest, what is an sv chassis?
To be honest, you hardly need plans for a wider car! Just add 50mm or 100mm (or whatever extra length you want) to the length of all the lateral chassis tubes! Easy!
To answer iank's question, the ChrisG plans are 2" wider than standard (Locost) design.
Just to be different I made my chassis 10% bigger by basically making every tube 10% longer!
HTH,
James
Simon
I (and several others) built mine (theirs) according to Ron Champions plans, but added 4" to the width. Easy peezy
Simon
Triton
posted on 7/2/09 at 11:00 AM Reply With Quote
Haynes Roadster?...wider by 2" than Uncle Ron's Locost.
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
iank
posted on 7/2/09 at 11:04 AM Reply With Quote
Alex
HTH,
James
SV is the wider version of the Caterham
Anonymous
Ninehigh
posted on 7/2/09 at 01:55 PM Reply With Quote
Wouldn't you have to source a wider rear axle and steering rack too?
Simon
posted on 9/2/09 at 08:05 PM Reply With Quote
Sierra is wider than Escort (and IRS to boot) and steering arm extensions sort out the steering
Simon
Ninehigh
posted on 9/2/09 at 09:11 PM Reply With Quote
Oh yeah not flicked through the book in a while
By the way are there other books for the Indy, IRS etc? Interested to know what they look like and such
wilkingj
posted on 10/2/09 at 12:18 PM Reply With Quote
How about a Luego Viento
6" wider, 12" longer and about 4" taller than Uncle Rons original.
Uses all Sierra (and I think Granada) running gear. Unless you are going for Mega power ie 300+ HP.
I have one with a V8 in it.
Have a look in my archive and at:
Linky
Made to fit a 6 pot BMW in it.
Have seen one done by Luego, and it fits nicely.
There is loads of room under a Viento bonnet.
You can even fit a V10 (but needs some strengthening on the chassis for those 500 horses!)
Other than that, the mc Sorley plans are good if you want to build the chassis youself.
Best Regards
Geoff
http://www.v8viento.co.uk
New Topic New Reply
