Slowmotion
posted on 8/2/09 at 01:52 PM |
Tiling direct to bricks. Is it OK?
I have been asked if I could complete a shower installation which was started by the homeowner.
One of the shower walls is bare brick which he sealed with PVA and has then started to tile direct on the bricks.
I wouldn't have dreamed of doing this but do you think it will be OK. I don't want to carry on with this method and then be blamed if
there is a problem in the future.
John.
posted on 8/2/09 at 01:56 PM |
I reckon it would be ok but the amount of adhesive you would use would be increased and the result flatness would be much more difficult to
achieve.
Personally I'd at least skim with plaster to flat it out a bit...
Pdlewis
posted on 8/2/09 at 03:17 PM |
Itll be ok but i would put a layer of base coat plaster (browning) on to provide a good surface to tile onto
Build Photo Album
Updated 05/02/2009
bigfoot4616
posted on 8/2/09 at 06:56 PM |
i do a lot of tiling and i would insist on covering the brickwork up first or not do the job.
best way is to stick plasterboard on with driwall adhesive, easier to get flat and can be tiled onto straight away. should leave 4 weeks for new
plaster.
any backing plaster(browning, bonding etc.) needs skimming before tiling and plaster can carry a lot less weight of tiles than plasterboard
as its a shower it should really be tanked before tiling but customers will never pay the extra for that
[Edited on 8/2/09 by bigfoot4616]
MikeR
posted on 8/2/09 at 08:25 PM |
Whats 'tanked' ?
Jon Ison
posted on 8/2/09 at 09:00 PM |
posted on 9/2/09 at 02:21 AM |
quote: Originally posted by MikeR
Whats 'tanked' ?
I'm interested to know too, never heard of it.
EDIT: Bit of research shows it's a waterproofing system for tiled walls used in wet areas. Seems it's now considered an essential thing
to have for tiled shower walls, despite the rather large number of showers installed without it that don't have damp problems. Seems to me that
if the grouting is done properly you shouldn't get moisture leaking past in the first place...
[Edited on 9/2/09 by MikeRJ]
