l0c0st
posted on 9/2/09 at 10:39 AM |
OT Help please, Scenic running rough
Hello all.
My X reg 1.6 16v Renault scenic has developed a severe lack of power and now sounds like a 2CV.
When idling the engine moves much more than it did before which manifests itself inside the car by the gearstick wobbling all over the place.
There haven't been any warning lights on the dash.
I have checked the resistance of the individual coils as suggested by the haynes manual, but they are all similar resistances.
I've also looked for leaks around the inlet manifold etc and can't find anything obvious.
Money's a bit tight at the moment so would rather not pay a garage and I'm off work on paternity leave so have a bit of time to spend on
it!
Dom
posted on 9/2/09 at 10:42 AM |
It might be worth hooking it up to a fault reader. Not all fault codes result in an a code on the dash.....
vinny1275
posted on 9/2/09 at 10:59 AM |
Could be a faulty lambda sensor giving dodgy readings to the ECU?
MK9R
posted on 9/2/09 at 11:02 AM |
The coils go on renaults (very common fault), my parents megane gets through one every 6 months or so. They split very very slightly and arc out. The
car looses power runs like crap and does terrible mpg.
[Edited on 9/2/09 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
dinosaurjuice
posted on 9/2/09 at 11:18 AM |
i know of a few 2.0l lagunas that have had this problem... with no fault codes or warning. if the 1.6 is a similar engine, its probably that.
MK9R
posted on 9/2/09 at 11:22 AM |
My parents is a 1.6. From what i hear it happens to all petrol renaults!! The AA actually carry them onboard there repair vans! My dad araldites the
crack up, its lasts about 3 months, so a free temporary fix.
Cheers Austen
RGB car number 9
www.trackace.co.uk
posted on 9/2/09 at 12:17 PM |
Change the coils and leads and plugs -- check plug gap before fitting.
It adds to the cost but the problem will be much less likely to return -- usually these problems are started by excessive HT voltage demands fromthe
plugs & leads. The excess voltage causes a spark to jump over the coil insulator creating a carbonised track.
Several different type of coils on these --- you may need to take old one with to get one also chassis number and engine type code.
I use this web shop quite often -- quick delivery & good service
http://www.ignitionleads.co.uk/index.aspx
Brook_lands
posted on 9/2/09 at 02:44 PM |
I'd go for coil packs as well - colleague always seems to have problems after wet weather - as commented AA carry them as a standard item and
charge about £35 a throw if they change one. Colleague's vehicle is the same as yours and has now had 4 changed in the lst couple of years
l0c0st
posted on 9/2/09 at 05:10 PM |
Thank you all for your replies. I've ordered a new coil and I'll pick up some new plugs tomorrow. Fingers crossed.
Cheers Dom
posted on 9/2/09 at 07:54 PM |
No leads on the Renault , direct to plug coil packs.
MK9R
posted on 10/2/09 at 07:38 AM |
yep, 4 seperate colild that plug onto top of spark plugs
Cheers Austen
RGB car number 9
www.trackace.co.uk
l0c0st
posted on 10/2/09 at 01:58 PM |
I've fitted the new coil and the car is back to it's old self.
The new coil came with some instructions to find which one of the four was faulty, which may be useful for anyone who has the same problem in
future.
All you need to do is, when the car is idling, unplug the connector on each of the fuel injectors in turn. The one that doesn't make the
misfiring worse is the one that's broken.
Thank you all for your help. Really chuffed to have the car running again without being too out of pocket.
Dom
MK9R
posted on 10/2/09 at 02:04 PM |
future.
Dom
Good news!!
See you can get something out of this site, other than just different ways to seriously empty your wallet!!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
