daniel mason
posted on 11/2/09 at 09:48 PM |
wheels and tyres
What would be your recommended choice for wheels and tyres for a R1 bec? not sure what size to go for. dif is 3.38 or 3.62 lsd.(not fitted yet) also
what tyres do you guys use and what sort of cost
Paul TigerB6
posted on 11/2/09 at 10:45 PM |
Not got one but helped to build one. Go for the 3.38 diff if you can and then look for a set of 13" wheels with 185/60/13 tyres (maybe 205/60/13
on the rear if you fancy a little more grip). We piked up a set of old Ford alloys that came out quite nicely for a very good price with a few cans of
paint and a large tub of elbow grease - have a look at 001Ben's pics
daniel mason
posted on 11/2/09 at 10:47 PM |
thanks paul. was thinking of 15" wheels due to the car bieng for road use only.
Paul TigerB6
posted on 11/2/09 at 10:51 PM |
maybe go for 195/50/15's then - seems to be a good choice of tyres in that size such as Toyo R888's etc. This will give a similar overall
diameter to the 60 profile 13's anyway and should suit the gearing of the R1 with a 3.38 diff. What brakes are you going with? Sierra rear disks
will probably push you towards the 15's anyway.
Run the figures for you. With a 195/50/15 tyre, the 3.62 diff gives 122mph max speed, the 3.38 gives 130mph max speed. Definately go for a 3.38 if you
can get one then.
[Edited on 11/2/09 by Paul TigerB6]
dhutch
posted on 11/2/09 at 11:51 PM |
A lot of people like the 15" for looks.
- Depends on budget, WSCC havea group buy on 13" race wheels which made them quite a lot cheaper.
Otherwise old ford capri wheels seams to be going for £50 a set all over the place.
- Im then looking at Yoko A048's tyres, possably the cheaper Toyo R888's
Cant help really, but thats might thoughts.
Daniel
mads
posted on 12/2/09 at 10:54 AM |
Just to put another element into the equation...
Other than cost (ignore for now), is there any reason why you wouldn't have 13" for the track and then change to 15" for the road
and looks? I'm thinking geometry setup, toe, camber, ride height etc. Would it make big differences to those?
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
progers
posted on 12/2/09 at 12:10 PM |
quote: Originally posted by mads
is there any reason why you wouldn't have 13" for the track and then change to 15" for the road and looks? I'm thinking
If you choose tyres with the same overall diameter (within a few mm) there is no real reason why you can't mix n match.
- Paul
posted on 12/2/09 at 12:41 PM |
The only difference you may notice is the unsprung weight and it's gyroscopic effect through the steering. But obviously that depends on there
being a noticeable weight difference between the 13" and 15" wheel/tyre combination.
Phil
Coose
posted on 12/2/09 at 09:01 PM |
13" wheels with Toyo R888s. There is no other option....
Spin 'er off Well...
Meeerrrk
posted on 12/2/09 at 09:26 PM |
cant decide between 13" & 15"?
go for 14s, i have
i think it depends what look your going for, i think mine sits perfectly on the 14s:
http://i63.photobucket.com/albums/h130/meeerrrk/LOCOBLADE010.jpg?t=1234473929
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
foes
posted on 13/2/09 at 10:03 PM |
too right...
Capri laser wheels, powdercoated matt black, toyo 888's...
When i bought my tyres, about 8 months ago, 888's were considerably cheaper than a048r's (which was my first choice).
