Author: Subject: do I need head restraints?
rumplitter
posted on 12/2/09 at 11:14 AM Reply With Quote
Morning all!
My question is, do I need head restraints?
The draft IVA quotes; "A system of head restraint must be fitted on every outboard front seat"
With me having a mini shell over the chassis I presume it's no longer outboard?
Regards
PJH
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
Mr Whippy
posted on 12/2/09 at 11:22 AM Reply With Quote
Don’t know what you think ‘outboard’ means but its simply the two seats as normal, unless your fitting three in a row like a Landy and then in that case the middle one needs no headrest.
Fit glass MK ones as they’ll look cool
rumplitter
posted on 12/2/09 at 11:24 AM Reply With Quote
i wasn't sure if outboard meant open top?
and inboard meant hardtop? Just seems a strange term to use!
Mr Whippy
posted on 12/2/09 at 11:33 AM Reply With Quote
Afraid not, outboard just means the outside ones, like outriggers on chassis for the supports on the outer perimeter of a chassis, or outboard and inboard motors on boats.
snapper
posted on 12/2/09 at 11:41 AM Reply With Quote
Its for cars with more than 2 front seats like the Aeon, the rule applies to the outer of the front seats
I eat to survive
I drink to forget
iank
posted on 12/2/09 at 01:22 PM Reply With Quote
I wouldn't consider sitting in a car without head restraints.
Whiplash hurts too much if you're lucky enough not to be killed.
Anonymous
Mr Whippy
posted on 12/2/09 at 02:04 PM Reply With Quote
also helps prevent your head bashing of the roll bar in a side impact. On GRP seats the head rest should be padded, as on an uncovered seat in a crash, your head would swing back slaming into it and probably kill you
speedyxjs
posted on 12/2/09 at 02:11 PM Reply With Quote
Hadnt read that part in the draft IVA. Lucky i ordered my seats with head rests
x_flow57
posted on 12/2/09 at 08:54 PM Reply With Quote
Looking at the draft manual this is the part that worried me regarding the seats and head rests
"Check that the height of the top of the head restraint above the H point
should be at least 800mm for the front outboard seats, and 750mm when
optional headrests are fitted to other seats.
Height adjustable head restraints must achieve this dimension at a position between the highest and lowest
positions to which adjustment is possible. There should also not be any in use position resulting in a height of less than 750mm."
The "H" poins is the block they put on the seat for the seat belt height check.
800mm is way over my head, certainly higher than the seats we have bought for Tim's challenger.
Nick
