Author: Subject: Building Inlet Manifold - Quick Question
adrianreeve
posted on 17/2/09 at 07:17 PM Reply With Quote
I'm building an inlet manifold for my bike bodies out out a laser cut flange and 45mm erw steel tube. My question is, how have other people put a lip on their steel tube to stop the rubber tubing connecting bodies to manifold from slipping off? If it was ali, I'd bead roll it, but don't think it will work with steel. Do you reckon a continuous bead of weld around the top of the tube would work ok?
All opinions and advice welcome!
Adrian
cryoman1965
posted on 17/2/09 at 07:21 PM Reply With Quote
Tack spots or even bird poo splatter will do. Need something slightly rough for the tube to grip.
N
big_wasa
cut a groove in the tube on a lathe.
jacko
posted on 17/2/09 at 07:25 PM Reply With Quote
I dont do any thing i have made 3 manifolds and had no problems
Jacko
painted manifold
painted manifold
[Edited on 17/2/09 by jacko]
*davies144*
posted on 17/2/09 at 07:28 PM Reply With Quote
second that! me and my friend made one not long back that seems to be fine without a lip
posted on 17/2/09 at 07:43 PM Reply With Quote
Have a look in the tools section for beading tool . Someone posted about one from B&Q a while ago
adrianreeve
posted on 17/2/09 at 08:00 PM Reply With Quote
The erw is only 1.5mm thick, so cutting a lip may be tricky. I didn't think the beading tool would work on steel tube. So by the looks of it, it's either weld or don't do anything, unless someone can tell me if the beading tool will work with 1.5mm steel tube.
Adrian
liam.mccaffrey
posted on 17/2/09 at 08:34 PM Reply With Quote
why don't you solder a piece of thick-ish wire around the pipe where you want the lip
Build Blog
Build Photo Album
MikeR
posted on 17/2/09 at 09:17 PM Reply With Quote
or even get a thin 3mm long bit of the same tube, cut it so it will slip over the existing tube and weld that on (all be it with a small gap - until you add another little bit).
posted on 17/2/09 at 09:25 PM Reply With Quote
24 hour heat proof epoxy. Bit of kite string. Glue string around bottom of tube. Done.
posted on 17/2/09 at 09:37 PM Reply With Quote
I machined a groove in the lathe - but I used aluminium, which was thicker. The ring on the Honda coupling rubber locks in there just nicely.
This is a picture of the test pieces I used to make sure everything was OK.
Danozeman
posted on 17/2/09 at 09:45 PM Reply With Quote
Id put a couple of spots of weld on. muchos easy and will work well, and your welder will be out when u make the manifold.
Dan
