wrigglypig
posted on 19/2/09 at 10:40 PM |
25 or 19
i have more 25 mm tube left than 19 and I am going to stat making the transmission tunnel is there any reason I could nt make it from 25mm will it
cause any problems or be of benifit?? your thoughts???
liam.mccaffrey
posted on 19/2/09 at 10:44 PM |
no problem at all. infact I think there was some analysis that showed the tunnel contributed almost nothing to the stiffness of the chassis unless it
was sheeted, bonded and riveted
Build Blog
Build Photo Album
RichieW
posted on 19/2/09 at 10:52 PM |
Remember the transmission tunnel isn't very wide as standard. You will lose either half an inch in width in the tunnel or 6mm from each side of
where your seats go if you use thicker tube. There's not much spare room there using 19mm as it is. If you're planning on using narrow
seats you will get away with it though.
stevebubs
posted on 20/2/09 at 12:09 AM |
Unless you have a centre bearing is losing 1/2in from the tunnel much of an issue? Prop's aren't that thick - the flanges are the
fattest...
rayward
posted on 20/2/09 at 01:00 AM |
fattest...
plus fuel pipes, brake pipes, wiring etc!
mad4x4
posted on 20/2/09 at 06:50 AM |
So at worst make it 1/2" taller if your that concerened......
Scot's do it better in Kilts.
