*davies144*
posted on 23/2/09 at 05:30 PM |
panard rod- ron champion chassis
hi is there a rod available to buy, to hold the rear axle from moving or do you make one??? anyone got any pics/info cheers ben
blakep82
posted on 23/2/09 at 06:49 PM |
best to make one i reckon. it very much depends on the accuracy of you brackets i think. I'd make one with rose joints so its adjustable. one
left hand thread, the other right handed. some might disagree, but thats how i'd do it
________________________
The Baron
posted on 23/2/09 at 07:02 PM |
YEah, speaking from experience, dont make the rod bar until you have assembled your car. Then make it to fit.
B
richard
posted on 23/2/09 at 07:18 PM |
Same as what we did so we could ajust it for the axle to fit square in the chassis. Did intend to weld it once we were sorted but not done it yet.
Danozeman
posted on 23/2/09 at 07:20 PM |
I got mine from MNR. Rosejointed on both end so you can adjust out any inacuracies.
Dan
*davies144*
posted on 24/2/09 at 07:12 PM |
excellent advice again, possible for anyone to send me a pic of theirs please?
blakep82
posted on 24/2/09 at 07:20 PM |
not a panhard, but a watts linkage on mine
not much use, i justed to show everone again
paulf
posted on 24/2/09 at 09:07 PM |
When I built mine I made one with a solid mounted bush at each end and then aligned the axle before welding the chassis bracket in place.
Paul
cjtheman
posted on 24/2/09 at 11:11 PM |
as above welded bracket to axle
made up panard rod fitted it to the car then tacked bracket on the chassis removed panard rod and weld away
job done
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
