Author: Subject: Jet size for 2L Pinto GSXR600 carbs
Paul TigerB6
posted on 25/2/09 at 04:26 PM Reply With Quote
Aft'noon all
Just looking for an approximate jet size for a set of GSXR600 (Mikuni) carbs on a standard 2L Pinto (205 block). The standard size is 1.25mm and i am guessing these may be slightly too small?? Anyone??
Paul
[Edited on 25/2/09 by Paul TigerB6]
whitestu
posted on 25/2/09 at 04:34 PM Reply With Quote
I'm running 1.6mm in ZX6R carbs on a 2.0 Zetec.
Seem to work OK, but haven't tested AFR yet.
Stu
blitzmk2
posted on 1/3/09 at 09:47 PM Reply With Quote
I am running ZX6R carbs on a 1700 crossflow 244 cam, flowed head and Megajolt, moved up progressively to 170 (1.7mm) jets, seems about right.
Paul TigerB6
posted on 1/3/09 at 11:41 PM Reply With Quote
Thanks gents. I'll drill the standard jets out to 1.5mm as a starting point then and see how it runs at that. Easy to then progressively increase the jet size till it runs well enough to get through SVA and then to the rolling road
