New Topic New Reply
Author: Subject: 1.6 zetec and type 9 in a ron champion chassis
*davies144*
posted on 25/2/09 at 05:48 PM Reply With Quote
hi just wondering if the standard chassis built to the book will be able to acccept a 1.6 zetec se and type 9 gear box? if anyone has used this combination and has some pics would be great to see them, cheers ben
Paul TigerB6
posted on 25/2/09 at 06:05 PM Reply With Quote
Zetec SE - like this one?
Should be a very easy fit - plenty have fitted bigger engines. Nice choice of engine btw
[Edited on 25/2/09 by Paul TigerB6]
*davies144*
posted on 25/2/09 at 06:24 PM Reply With Quote
that the one doesnt quite look like yet though!!! so do you think the gearbox will fit without alteration needed to the chassis
?? ben
Paul TigerB6
posted on 25/2/09 at 06:26 PM Reply With Quote
The type 9 isnt very wide at all so cant see it being an issue. I'm sure someone will confirm specifically for the Ron Champion chassis shortly.
The Baron
posted on 25/2/09 at 06:48 PM Reply With Quote
I dont think the Type 9 will fit in a standard Book chassis, easily fixed with a angle grinder and re-welded.
B
Gazeddy
posted on 25/2/09 at 06:54 PM Reply With Quote
which zetec? escort or focus
escort one will bolt to a t9 but why not go 2litre and rs1800 cams.
focus one will need a new bellhousing as the bolt pattern is different
[Edited on 25/2/09 by Gazeddy]
*davies144*
posted on 25/2/09 at 07:00 PM Reply With Quote
it came from a 2000 fiesta zetec s, well i thort id go for a smaller engine because i am only 20 so my insurance will be bad enough with a 1.6!!!
Paul TigerB6
posted on 25/2/09 at 07:02 PM Reply With Quote
Have you already got the chassis then??
*davies144*
posted on 25/2/09 at 07:08 PM Reply With Quote
yeh bought the chassis a couple of weeks back
Paul TigerB6
posted on 25/2/09 at 07:10 PM Reply With Quote
might be worth measuring across the transmission tunnel then and popping the numbers up. No doubt someone will have a type 9 who can measure the width behind the bell housing
UncleFista
posted on 25/2/09 at 07:15 PM Reply With Quote
I can confirm a type9 fits in a standard Champion "book" chassis quite easily.
It's the Zetec[1] that's a tight fit
[1] Silvertop, not small...
Tony Bond / UncleFista
Gazeddy
posted on 25/2/09 at 07:20 PM Reply With Quote
its a blacktop. which is smaller but doesnt fit the type 9 box without a new bellhousing
Mix
Hi
Type nine isn't too big a problem. The engine however is taller and ideally requires the chassis sides to be raised an inch.
Regards Mick
*davies144*
posted on 25/2/09 at 07:24 PM Reply With Quote
good stuff about the gearbox, what engine would you go for as a cheap to insure car, 1.6 cvh???
Paul TigerB6
posted on 25/2/09 at 07:25 PM Reply With Quote
The all alloy Zetec SE is a much smaller engine though - more like the Toyota 4-age in size than the taller 1.8 / 2.0 Zetec's. The bellhousing is on Shawspeed's website linked to earlier - just not so sure they are still trading. There is another company doing stuff for the Zetec SE isnt there??
Try a search for info - i know i have seen someone on here with this engine
Paul TigerB6
posted on 25/2/09 at 07:29 PM Reply With Quote
You will be looking at a specialist policy and you might well find the engine size doesnt actually make that much difference. Even so, i would rather pay a bit more on insurance for a couple of years and build the car how i want it rather than just to reduce the insurance costs (and it may cost you more in the long run trying to fit a less common engine)
Try a search for insurance for under 25's on here and maybe ask what premiums the under 25's are paying - i'm sure most will happily tell you
Gazeddy
posted on 25/2/09 at 07:32 PM Reply With Quote
try 1.4 cvh then you can change to the much nicer and tougher zetec e eventually
my personal opinion. although im think of building a chassis to take a 3.2 5 cyl tdci transit engine.
Daddylonglegs
posted on 26/2/09 at 01:21 PM Reply With Quote
Not sure if this'll help?
Type 9
JB
*davies144*
posted on 26/2/09 at 06:44 PM Reply With Quote
cheers thanks for the help
posted on 26/2/09 at 08:13 PM Reply With Quote
I have a type 9 box in my standard chassis - it's positioned to that the back face of the bellhousing is about 1cm away from the chassis uprights.
There's a fair bit of room all around in the tunnel.
New Topic New Reply
