New Topic New Reply
Author: Subject: Older westfields
ell_bkr
posted on 27/2/09 at 03:56 PM Reply With Quote
Older westfields
Hi all, my first thread here and i'm sure it wont be my last
I'm currently in the market for my first kit car. Unfortunatley i have a rather low budget of around 3 to 4k.
On looking around it appears that the tiger cat e1 would be a good option, and if it wasnt for this forum i would have probably already bought one. Reason I haven't is because of the rather heavy rear suspension set up.
I've also seen a few westfields up for sale for around the 4k mark, most of which were built in the 90's. My question is this:
Would I be better off getting an older westfield over a newer tiger cat? Have westfields changed much over the years or are they just as good today as they were in the 90's?
Its probably worth mentioning that I am hoping to do some sprints and hill climbs in the car so i'm sure weight is a very important concideration
Cheers in advance!
whitestu
posted on 27/2/09 at 04:02 PM Reply With Quote
Why not buy this:
Link
ell_bkr
posted on 27/2/09 at 04:59 PM Reply With Quote
Originally posted by whitestu
Why not buy this:
Link
I did get rather excited when i saw that this morning, however i think i may have been beaten to it by somebody else I've u2u'd and called him with no response.
timcullen
posted on 27/2/09 at 05:37 PM Reply With Quote
My Westfield (Live Axle) Was built in 1989 it is a very competitve sprint car with no chassis mods just corner weighting, anti-roll bar and proper set up etc.
It runs a crossflow and is 470kg. Its quicker than a lot of the Zetec boys! That makes me happy!
dhutch
posted on 27/2/09 at 08:07 PM Reply With Quote
I was in a simular situation, and after looking at a few pinto engined MK indys around the £4k mark (and one very tatty 4yo zetec indy) i settled on a westfeild.
- Mines a 1991 narrowbody with live rear and a 1.9l CVH engine.
- Had the car weight a few months ago at 540kg so not stupidly heavy.
Im fairly sure the dampers are the origanals or close to, but other than that it goes very well indeed and im very happy with it.
Daniel
posted on 2/3/09 at 12:08 PM Reply With Quote
Explain why that is such a bad thing?
ell_bkr
posted on 2/3/09 at 06:31 PM Reply With Quote
Why you asking me i'm the newbie seeking advice here!! I'm just going by what i read on the internet!
So i'm guessing you think otherwise do you?
[Edited on 2/3/09 by ell_bkr]
posted on 3/3/09 at 01:53 PM Reply With Quote
well all I can say is that there are hundreds, if not thousands of live axle sevens out there - the early caterhams had that set upo and they went pretty well.
this should not put you off.
DarrenW
posted on 3/3/09 at 03:04 PM Reply With Quote
At the risk of confusing the thread, doesnt one of the tigers use the complete sierra rear suspension unit and thus have a reputation for heavy back end and compromised handling? Maybe that is the tiger the OP is referring to.
I agree ref live axle - that is a proven set up and whilst an older design not necessarily a bad thing. Id be tempted to go for older Westie rather than some newer others.
wilkingj
posted on 4/3/09 at 03:33 PM Reply With Quote
I suppose it depends on how heavy the engine is and where its sat.
Basically the ballance of the car should be taken into consideration.
You say they have a heavy rear end due to the oringinal Sierra Beam etc.
Yes it does use that part. However, its the weight distribution of the finished car that REALLY matters. It could be perfectly ballanced or not, as the case may be.
Dont assume just becaue it used the Whole sierra beam and wishbones the car is badly ballanced.
Having said that, I have no idea of whether Tigers are well ballanced or not.
Stick them on a set of Scales and find out!
Its not Rocket Science
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 4/3/09 at 05:16 PM Reply With Quote
As Darren says, the Tiger Cat uses the entire Sierra rear subframe and semi-trailing arms. Not only does this weigh a metric sh1tload, it also gives rather compromised geometry. The Robin Hood 2B uses the same system.
posted on 5/3/09 at 08:41 AM Reply With Quote
aaah, gotcha; I wasn't aware of this sierra subframe stuff but asssumed it was the old escort/capri live axle set up ; did Westfield ever use the sierra subrafme?
posted on 5/3/09 at 08:45 PM Reply With Quote
No, they used the diff, driveshafts and hubs etc. but not the subframe and trailing arms.
ell_bkr
posted on 8/3/09 at 01:50 PM Reply With Quote
Thanks for the advice everyone, think i'm going to avoid the tiger cats then and keep searching for an older westfield.
New Topic New Reply
