Author: Subject: Identification of "stuff" on GSXR600 SRAD carbs
Paul TigerB6
posted on 3/3/09 at 03:53 PM Reply With Quote
Can someone tell me what the two black units are (each seems to be connected to a pair of carbs), which are bolted to the underside of the GSXR carbs please. They have twin hoses going into / out of each and a two pin electrical connection on.
I am guessing they are part of the emmissions control (air injection maybe), as are the 4 the multitude of hoses that connect to the 4 brass inlets on the lower part of the carbs??
Do these need blocking off or leaving open to air??
Should say these have been respaced and are going on a boat anchor........ sorry...... Pinto
[Edited on 3/3/09 by Paul TigerB6]
cryoman1965
posted on 3/3/09 at 05:07 PM Reply With Quote
Not required. Block the hoses off.
Nige
Paul TigerB6
posted on 3/3/09 at 05:10 PM Reply With Quote
Excellent thanks. Guessed they must be a pair of solenoid valves from the manual - can find very little on them there!! Will remove them and block the pipes up this evening then
Paul
