Author: Subject: Panel foam/seal
phil_far
posted on 3/3/09 at 05:53 PM Reply With Quote
Panel foam/seal
Hi
Do you put any form of 'insulation' material between the fibre/alloy bodywork and the chassis rail i.e. like foam or rubber strip? If yes from where do I purchas eteh stuff?
Philip
jacko
posted on 3/3/09 at 06:08 PM Reply With Quote
no i just glued the panels on with sikaflex
Jacko
Stuart_B
posted on 3/3/09 at 06:11 PM Reply With Quote
i just glued mine on with tiger seal
stuart
jlparsons
posted on 3/3/09 at 06:46 PM Reply With Quote
Were you thinking along the lines of damping the panels? I was pondering this but concluded it'd be like chucking a deckchair off the titanic. I might be wrong though, it has happened before...
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
phil_far
posted on 4/3/09 at 05:42 PM Reply With Quote
My panels are all removable including the side panels. So I was thinlking of insulating them all as weall as the fibre glass body for that matter. However it seems that I am the only one... .thanks anyway
Philip
jabbahutt
posted on 5/3/09 at 08:18 AM Reply With Quote
all my panels including the sides are also removeable. I didn't use any foam etc to reduce vibration and haven't noticed any so far.
The car has only done 120 miles though since SVA
