frankycopp
posted on 3/3/09 at 06:01 PM |
blade 893 wiring
has anyone got a blade 893 wiring diagram need to no where the neutral wire and oil wire goes to on engine thanks
Mark G
posted on 3/3/09 at 06:36 PM |
If you u2u me your email I'll send you over a pdf document which explains exactly what to do with all of the wires from the blade engine loom.
Mark G
posted on 3/3/09 at 06:54 PM |
sent
Kev99
posted on 3/3/09 at 07:17 PM |
worked ok for you then Mark?
Mark G
posted on 3/3/09 at 07:21 PM |
so far so good, all but the rev counter although I think thats more a problem with my Koso rather than the wiring from the engine.
did you make the document?
[Edited on 3/3/09 by Mark G]
Kev99
posted on 3/3/09 at 07:29 PM |
No pinched it of somebody's website cant remember whos, I Think the sites not there anymore. I will advise people to use the superdream
rectifier as the blade ones prone to blowing as I went through 2 before I changed mine
Mark G
posted on 3/3/09 at 07:30 PM |
well it helped me out.
I'll bear in mind about the blade reg tho, ta.
mad-butcher
posted on 4/3/09 at 09:27 AM |
Mark G
just wondering if it's the same doc as I have by dodgy roger covers making extended ht leads and which wires to cut out of blade loom. his
website seems to have disappeared
tony
