*davies144*
posted on 3/3/09 at 06:57 PM |
type 9 gear lever
hi i know that you can buy a quaife shift that gives a shorter throw for the type 9 but is there a 'tight' way of some how making the
standard lever any more precise? cheers ben
Paul TigerB6
posted on 3/3/09 at 07:04 PM |
I did one myself - there is a website detailing how to do it somewhere. If someone doesnt beat me to it i'll have a look for it now. I chopped
the rubber damper out and shortened the gearstick considerably while i was at it
flak monkey
posted on 3/3/09 at 07:06 PM |
Rest the plate on the vice jaws, with the selector fork between the jaws.
Whack the end of the gear stick with a big hammer and it will move through the ball. Knock it through 8mm, and use some drilled out M8 nuts as spacers
when you bolt it to the gearbox
[Edited on 3/3/09 by flak monkey]
Sera
http://www.motosera.com
SteveWalker
posted on 3/3/09 at 07:14 PM |
You could take a look at http://www.joeybrown.co.uk/quickshift/quick.html
SteveW
