Author: Subject: Sierra DOHC Bits needed
Gareth
posted on 5/3/09 at 02:27 PM Reply With Quote
Need a couple of bits off a DOHC Sierra/Scorpio engine.
Local Breakers no help so far.
Oil Dip Stick and Pipe.
Alternator Bracket and adjuster
Air Intake Pipe (just to mount the Idle Sensor)
I am located in Colchester Essex but work in Ipswich Suffolk.
Gareth
UncleFista
posted on 5/3/09 at 09:24 PM Reply With Quote
If you're stuck I can have a drive to this place at the weekend for you if you like
I've bought a couple of bits from him in the past, although he's not the cheapest
As I say, it'd be cheaper to get the bits closer to home, but if you're stuck I can obtain 'em and post...
[Edited on 5/3/09 by UncleFista]
Tony Bond / UncleFista
Gareth
posted on 6/3/09 at 02:42 PM Reply With Quote
Cheers Tony
I may need to take you up on this but hopefully have found the bits I need locally (will find out Monday).
Gareth
Gareth
posted on 11/3/09 at 02:47 PM Reply With Quote
Sierra DOHC Bits Wanted
BTTT - Sierra DOHC Bits needed
Alternator Bracket and adjuster.
Alternator Pulley (flat belt type).
Waterpump Pulley (flat belt type).
Air Intake Pipe (just to mount the Idle Sensor).
Engine Breather Hoses
Tony sent you a U2U.
Gareth
