Northy
posted on 13/2/04 at 06:26 PM |
Clutch pedal setup?
Have people using the Luego floor mounted pedal box fitted the nylon insert thing and spring refered to in the build manual? (Photo below).
If so where did you get the nylon dodab? I'm sure I'll be able to find a spring, but can't find anything nylon that will fit.
![](/galpreviews/a85177-Image1.jpg) ![Rescued attachment Image1.jpg](/gallery/a85177-Image1.jpg) Rescued attachment Image1.jpg
Graham
ChrisW
posted on 14/2/04 at 12:09 AM |
I've just drilled through and used a Cortina cable and a 'Conrod engineering' bolt to stop the pedal coming forward. No sign of a
nylon thing.
Can get a photo if you like?
Chris
My gaff my rules
Northy
posted on 14/2/04 at 09:03 AM |
Please Chris if you don't mind
Anyone else out there fitted their clutch pedal yet?
Graham
Gazza
posted on 15/2/04 at 01:42 PM |
Split Nylon Bush
I managed to talk nicely to a local engineer who provided me with a length of hollow nylon rod - all I had to do was cut it to length and then cut it
down its length to enable me to fit the cable in it.
Works a treat and stops the cable rubbing on the chassis....
Just a bag o' rusty spanners
