New Topic New Reply
Author: Subject: INDY BEC RIDE HEIGHT AND GAZ SHOCKS
matt.c
posted on 11/3/09 at 11:14 PM Reply With Quote
After finding out tonight that i put my springs on the wrong way ie fronts on the back. Dumb arse!! I now need to setup the ride height. Whats the ideal ride height front and back for my indy? Not worried about speed bumps etc.
Also im using GAZ shocks and they have around 45 clicks (settings) How do i know how many clicks to have them on??
175's Front
225's Rear
GAZ shocks
ReMan
posted on 11/3/09 at 11:19 PM Reply With Quote
Front lower wishbones JUST below level
Rear chassis rail 10-15mm higher than front about right for me on 15's
ReMan
posted on 11/3/09 at 11:20 PM Reply With Quote
IDONTBELEIVEIT
posted on 12/3/09 at 07:35 AM Reply With Quote
westy megablade
front 95mm from FFL to bot of chassis
rear 110mm fromFFL to bot of chassis
cheers wayno!!
Are We There Yet, Are We There Yet!!!!
afj
posted on 12/3/09 at 09:07 AM Reply With Quote
is the poundage of the springs printed or stamped on, on the protech shocks, i cant remember what i got from mk or which end i put em
eerrrrrrrrrrrrrrrr
MikeCapon
posted on 12/3/09 at 11:50 AM Reply With Quote
Hi afj,
If you can't find the rates for your springs it is possible to tell the rate from measuring the OD, the wire diameter and the number of coils. I can let you have a spreadsheet for this if you want.
Mike
posted on 12/3/09 at 12:21 PM Reply With Quote
Depends whether you're car is used mainly on road or track. If mainly road, then surely you need to be concerned about speed humps etc
If used purely on track, then you can slam it as low as you want.
Phil
afj
posted on 12/3/09 at 01:56 PM Reply With Quote
sorry to hijack but mine seem to be 350 front 200 rear any suggestions
eerrrrrrrrrrrrrrrr
ReMan
posted on 12/3/09 at 09:38 PM Reply With Quote
Your engine is too heavy?
matt.c
posted on 12/3/09 at 10:50 PM Reply With Quote
Phil
Mainly road use but i dont like the 4x4 look. I think i read somewhere about the wishbones being parallel? Is this right? Or doesnt it matter?
procomp
posted on 13/3/09 at 09:56 AM Reply With Quote
Hi Matt
The thing with the Indy is that the usual rules where people use the lower wishbones or pivot point's being level dose not really work on the Indy's. what you have to do is load the car up in roll simulation and map out the camber changes. This is not the same on all the cars as it depends on what ride height you are thinking of running. and the Dia of the tyres you are running.
Given that the camber control at both the front and the rear is not particularly good it means having to compromise and try to achieve as good as you can control of the camber. This usually means running camber settings that are not found as standard settings on many other similar type cars. ( Bar the Mac#1 ).
If you are at Snetterton the weekend I'll give you a bit more of an idea ect as it's a bit easier to explain with a car in front of you than text only.
Cheers Matt
matt.c
posted on 13/3/09 at 06:40 PM Reply With Quote
Ah matt, i was going to ask where you will be on sunday? Will be there all day so plenty of time to chat.
New Topic New Reply
