Paul (Notts)
posted on 13/3/09 at 06:21 PM |
engine misfire or stumble - help
Ideas needed…
The car has been running really well recently until last night I ventured out to the local Westfield meet. After a few second the car seemed to
misfire or more accurately stumble. Seems worst when you try to accelerate.
Car is running EDIS 8 and a Webber 5000 carb.
Plan of action for Saturday includes
1 checking the VR sensor mounting
2 plugs
3 leads
4 wiring to edis and coils and megajolj.
What else could be the problem. Just gets on my nerves as it was running so well and the it pulls a moody.
Paul
flak monkey
posted on 13/3/09 at 06:24 PM |
Is your fuel tank breather blocked?
Sera
http://www.motosera.com
Paul (Notts)
posted on 13/3/09 at 06:30 PM |
good idea!!!!
[Edited on 13/3/09 by Paul (Notts)]
big_wasa
posted on 13/3/09 at 06:32 PM |
fuel filter blockage ?
posted on 13/3/09 at 06:40 PM |
Could the carb be flooding? Could cause your problems , whip a plug out and check colour. Check for air leaks? Quick squirt of WD40 around the carb
base, manifold etc.
wrigglypig
posted on 13/3/09 at 06:58 PM |
when you get it started from cold , quickly feel the headers near the head the should all get warm evenly, cold ones mean they aint firing, it will be
a start for you, Let us know how you get on
Kev
Paul (Notts)
posted on 13/3/09 at 07:09 PM |
If you just let it idle then its fine, and will rev in neutral ok. Only seems to be a problem under load.
Bigheppy
posted on 13/3/09 at 07:27 PM |
Could it be running on the edis limp home mode.
handyandy
either an air leak or plug lead breaking down,
imo.
andy
posted on 13/3/09 at 08:23 PM |
If the air temp was cold it could have been carb icing, however generally.
If the engine was previously running well --- if it hiccups under load it is fuel related, a misfire under load tends to be ignition.
If the loss of power happens two or three seconds after giving the engine throttle the problem is between the float chamber and the tank. --- start
by checking the fuel line ines are clear from the pump back to the tank -- be way to do this is remove the filler cap, disconnect the pipe at the
pump inlet and blow back to the tank with a foot pump --- if it is clear you will hear lots of bubbles i the tank.
Then disconnect at carb inlet and fuel pump outlet and blow back from the carb end to the pump.
Remove the float chamber lid check for signs of water in the fuel and check the carb float valve is clear.
Check all the cab jets are clear and the accelerator pump is working.
Paul (Notts)
posted on 13/3/09 at 08:39 PM |
Defiantly more of a hiccup than a misfire so will have a good look at the fuelling.
Thanks for that
Paul
Paul (Notts)
posted on 14/3/09 at 04:44 PM |
cleaned fuel pump filter and then cleaned carb. reset float heights.
also moved any ignition lead that was close to rocker cover.
now runs better than ever.
thanks for the advice.
Paul
