Author: Subject: buying a cat C car as a Donor
cryoman1965
posted on 14/3/09 at 10:53 PM Reply With Quote
if you buy a cat C as a Donor how do you get by with the vic check/registration docs.
Nige
dinosaurjuice
posted on 14/3/09 at 11:03 PM Reply With Quote
you have to get the car VIC checked.
annoying thing is they wont inspect the vehicle if it has broken glass or obvious damage.
Chippy
posted on 14/3/09 at 11:46 PM Reply With Quote
If you use a Cat C as a donor, wouldn't you just end up with a "Q" plate reg?Cheers Ray
snapper
posted on 15/3/09 at 08:05 AM Reply With Quote
My donor came with a receipt from the breakers stating that "This vehicle has been seriously damaged, the milage is disclaimed and sold as seen with no guarantee"
No problem with DVLA and i got an age related
I eat to survive
I drink to forget
posted on 15/3/09 at 10:26 AM Reply With Quote
You would only need a VIC if you were putting the original car back on the road. If you use it as a donor you will be permanently scrapping the original vehicle anyway but if you have the documents you will have proof of age automatically.
Ninehigh
posted on 15/3/09 at 06:26 PM Reply With Quote
Iirc cat c is technically repairable so there shouldn't be a problem as a donor, all you're using is the engine and gearbox!
