Author: Subject: quaife reverse box, full prop shaft and 3.38 rear diff
MK9R
posted on 16/3/09 at 08:08 AM Reply With Quote
I am about to swap my rear diff and remove my quaife reverse box so its all up for sale. Ideally i'd like to sell as a complete package. It is currently fitted to a stuart taylor locosaki, so will fit most cars without any modifications.
Items included
Quaife reverse box
Linky
Front and rear prop shaft
3.38 sierra rear diff complete with drive shafts
Everything is perfect working order, i'm only selling it as i don't require the reverse box anymore as the car is purely for racing.
The items are still fitted to my car so can be seen running, and will only be available once i have sourced the replacement parts. The driveshaft are only available if i change diff types
I'm looking for a 3.14 diff (complete or just gears) or failing that a freelander diff, and a replacement prop shaft.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 16/3/09 at 08:19 AM Reply With Quote
How much for the diff my man... Inc postage. Sorry don't need the reverse box
MK9R
posted on 16/3/09 at 08:24 AM Reply With Quote
oops sorry to post prices!! to be honest i don't know what they are all worth.
I do want to see if i can sell as a package first, and depending on what i can source i may have to keep the diff to use it to rebuild with a 3.14 internals.
Cheers Austen
RGB car number 9
www.trackace.co.uk
fesycresy
posted on 16/3/09 at 09:01 AM Reply With Quote
u2u sent
MK9R
posted on 16/3/09 at 09:04 AM Reply With Quote
Originally posted by fesycresy
u2u sent
not received. email me if you want austen.greenway@virgin.net
Cheers Austen
RGB car number 9
www.trackace.co.uk
fesycresy
posted on 16/3/09 at 10:22 AM Reply With Quote
email sent
u2u sent
MK9R
posted on 16/3/09 at 10:36 AM Reply With Quote
you have u2u
Cheers Austen
RGB car number 9
www.trackace.co.uk
frodo_monkey
posted on 16/3/09 at 01:06 PM Reply With Quote
Hi Austen,
If I were you I would check the Blue Book first - I am pretty convinced that you DO have to have a reverse gear for racing, because that was one of the factors that made me buy my car.
I'd check but a) the MSA website is down, and b) I'm at work whereas my copy is at home...
Regards (and standing-by to be corrected),
Frodo
"Racing is life. Anything before or after is just waiting."
MK9R
posted on 16/3/09 at 01:14 PM Reply With Quote
Originally posted by frodo_monkey
Hi Austen,
Frodo
Yes need a reverse, but going to put a light weight electric one in
Cheers Austen
RGB car number 9
www.trackace.co.uk
phil_far
posted on 16/3/09 at 01:23 PM Reply With Quote
U2u sent re-reverse box and prop shafts.
I have a full length prop shaft brand new (covered 1 mile trail run )if you are interested to swap.
Regards
Philip
Andy B
posted on 16/3/09 at 04:12 PM Reply With Quote
Hi Austen
give me a bell at the unit re your diff etc and I will tell you what you need to be competitive with the 919. 3.14 or 3.21 isnt going to be right for what you are doing, trust me I've been there.
regards
phil_far
posted on 18/3/09 at 06:52 AM Reply With Quote
You have U2u re prop lengths and price
Philip
MK9R
posted on 18/3/09 at 07:30 AM Reply With Quote
phil, u2u replied to
Cheers Austen
RGB car number 9
www.trackace.co.uk
