*davies144*
posted on 16/3/09 at 06:20 PM |
2.0 cam in a 1.6 pinto engine
hi, first of all will it fit? secondly will the head need any modifications?
tomprescott
posted on 16/3/09 at 06:21 PM |
Yeah it will fit and you shouldn't need any modifications (aside from ignition timing) but its worth checking over the condition of your oil
spray bar and the followers springs and replace any weak parts with new.
*davies144*
posted on 16/3/09 at 06:23 PM |
ok, so what will it do will it improve the throttle response etc?
Stuart_B
posted on 16/3/09 at 07:21 PM |
hi, it was talked about here by me and some others. hope this helps a bit.
p.s. if you read it, i have not got a 2.0litre head the on my 1.6pinto
stuart
posted on 16/3/09 at 07:33 PM |
Read up on the Puma racing web site ---
mark chandler
posted on 16/3/09 at 08:04 PM |
No modifications, the 2.0 litre cam was standard fit in the 1.6GT engine.
The 1.6GT engine also had larger valves, banana exhaust and twin choke webber, it was basically a skimmed 2.0litre head.
So will be a straight swap in, will make the car a bit more eager
