Author: Subject: what to run a pinto 1.6 on bike carbs on????
*davies144*
posted on 17/3/09 at 09:13 PM Reply With Quote
hi just wonderd what would be the best management system to use on my set up?
clairetoo
posted on 17/3/09 at 09:15 PM Reply With Quote
Megasquirt
Its cuz I is blond , innit
Claire xx
Will weld for food......
Paul TigerB6
posted on 17/3/09 at 09:17 PM Reply With Quote
MegaJolt - simple answer. Solder your own from a kit for about £50. Buy the Edis 4 bits from a breakers yard for around £35 and maybe £15 for wire. I did a megajolt system and included 5 LED's for the shift lights for around £120 all in on a 2L Pinto (which is having the bike carbs fitted tomorrow)
omega0684
posted on 17/3/09 at 09:31 PM Reply With Quote
i would go for the megajolt route unless you plan to use ITB's, then i would go Megasquirt!
jacko
posted on 17/3/09 at 10:04 PM Reply With Quote
modified dizzy from H&H ignition solutions
fit the dizzy and off you go
Jacko
RichardK
posted on 17/3/09 at 10:17 PM Reply With Quote
Megajolt, no question.
Cheers Rich
Gallery updated 11/01/2011
