dan__wright
posted on 22/3/09 at 02:25 PM |
rear suspension problem
i will be taking the indy for a full track setup next month but for now ive just set it up by eye.
most of its okay but the rear is a bit twitchy, okay on smooth roads but if its bumpy the back end wanders over the road.
the other concerning problem is i accelerated up to 95 on some private land and it was okay, but as soon as i backed off the back end jumped to the
left!
any ideas?
how should i have it set (height, shock settings, tyre pressure, camber?)
posted on 22/3/09 at 02:31 PM |
I suspect you need to check the rear toe-in
Plan of action
(1) Toe-in and alignment
(2) Corner weights
posted on 22/3/09 at 02:32 PM |
Oh --- and also make sure the dampers are set very soft
cryoman1965
posted on 22/3/09 at 03:00 PM |
Are the wishbones and associated bits done up tight enough. Had a simular problem with mine.
Nige
