foes
posted on 22/3/09 at 07:01 PM |
rear fog light wiring...?
I've finished wiring my car up using the stm/aries supplied loom and switches, now, the rear fog works when i put the side/dipped lights on but
as soon as i switch main/high beam on the rear fog light goes out, is this ok...?
blakep82
posted on 22/3/09 at 07:03 PM |
sounds right i think?
________________________
Paul TigerB6
posted on 22/3/09 at 07:04 PM |
Thats how it should be - the fog light should take a feed off the side lights so it goes off as soon as you turn the lights off
supermoto
posted on 22/3/09 at 07:06 PM |
do you need to switch the fog on or does it come on on its own..?
and with the fog switch on does it go out when you turn on the Main lights?
sounds wrong to me...but hey what do i know....i've guessed at my entire loom!
foes
posted on 22/3/09 at 07:10 PM |
Yes but it also goes off when i switch main beam on, is this correct..?
matt_claydon
posted on 22/3/09 at 07:14 PM |
It shouldn't go off with main beam.
Side ('position' ) lights should stay on all the time even when dip or main is also on (since they define the width of the car and
aren't necessarily in the same place as the main beams) and fogs should be able to operate whenever the sides are on.
[Edited on 22/3/09 by matt_claydon]
blakep82
nooo, thats not right. can you take the power feed from the sidelights (as they should stay on regardless of what the headlights are up to)
foes
posted on 22/3/09 at 07:41 PM |
hmmm, thing is it's a pre wired loom that stm/aries supply so i don't think i can of connected it up wrong.
Will it not pass sva like this then?
adithorp
posted on 22/3/09 at 08:10 PM |
Fog light always used to be wired (on many older tin-tops) so it was off when you switched from dipped to main beam. Now they tend to stay on. Either
way is ok for SVA. You shouldn't be using main beam in fog anyway; too much glare from the fog.
http://jpsc.org.uk/forum/
foes
posted on 22/3/09 at 08:17 PM |
Phew, that was my thoughts exactly about using main beam in the fog, cheers.
