frankycopp
posted on 1/4/09 at 07:25 PM |
893 baffle plate
wheres the best place to get a 893 baffle plate ?or does anyone have one for sale?
prawnabie
posted on 1/4/09 at 07:26 PM |
try andy at AB performance he knows his blades
McLannahan
posted on 1/4/09 at 07:53 PM |
I've just bought one for my 919 this week from Andy. Prompt postage and spot on advice and help from him too.
Can't fault him - excellent service. If only dealing with other KC and KC related businesses was as pleasant and simple!
Jon Ison
posted on 1/4/09 at 09:04 PM |
893 blade, dont bother.
mark chandler
posted on 1/4/09 at 10:29 PM |
I had a google at some pictures, then just got a bit of 1/4" Ali and cloned.
This takes 10 minutes with a jig saw.
What takes more time is cutting and welding the sump + shortening the pickup and oil return to suit, but only needed if you are trying to reduce
underhang.
Regards Mark
hobbsy
posted on 1/4/09 at 10:50 PM |
Don't really need one on early blades do you - as Mr Ison said...
Andy B
posted on 2/4/09 at 09:47 PM |
We run all our carbed blades on baffle plates, both 893cc and 919cc.
Basically oil surge is directly related to how fast you drive the car and how hard you are on the brakes. The forces within the engine when cornering
in a bike which leans through corners, serve to keep the oil flat in the sump. However in a car cornering hard the oil is thrown up the sides
allowing the pick up to run dry and oil pressure to drop - at this point it is curtains for the shells somewhere along the line.
Whilst road cars seldom achieve the levels of cornering and braking we view the £35 cost of a baffle as a relatively small expense versus the cost and
hassle of a blown motor. As for trackday or race use I would not go near a track without one fitted and for the extremes of racing we also move onto
the replacement billet sump as a baffle alone wont be sufficient.
Hope that helps
regards
