chrisg
posted on 4/4/09 at 02:26 PM |
Blade relay - what is it?
I'm thining down the blade loom but I can't identify one relay.
The code is omron G8MS-H34
Any ideas?
I think it might be something to do with the lights but I can't find it on google.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Flamez
posted on 4/4/09 at 03:00 PM |
photo would help chris, relays usually sit on top of ecu
my build mac1motorsports
chrisg
posted on 4/4/09 at 03:04 PM |
I'll post one in a bit
cheers
Chris
slimtater
posted on 4/4/09 at 07:04 PM |
Not sure if these help:
http://archive1.gwrra.org/discus4/messages/93986/176009.html?1215748081
how much for headlight?
also there is this thing behind the headlight along with all the wires
I think its a headlight relay or something but the thing is black and blue around the connecting point
OMRON
G8MS-H34
12V10A NC
0225d6
I need that piece
http://www.picturetrail.com/sfx/album/view/19919222
chrisg
posted on 4/4/09 at 08:22 PM |
This is it
[img][/img]
Chris
chrisg
posted on 5/4/09 at 06:39 PM |
Any ideas chaps?
mad-butcher
posted on 6/4/09 at 07:32 AM |
what year is wiring off ,can't find a pink (yet) in a 96/99 blade workshop manual
tony
chrisg
posted on 6/4/09 at 12:26 PM |
The thing is I'm not sure.
I've only got the 92-95 wiring diagram, which doesn't have a pink wire either.
Bugger
Chris
chrisg
posted on 7/4/09 at 07:24 PM |
bump
McLannahan
posted on 7/4/09 at 07:56 PM |
Isn't the pink wire in a later blade loom the immobiliser? Is in mine at least, mine's a 97.
motorcycle_mayhem
posted on 8/4/09 at 09:44 PM |
On my GSXR's that *very same* relay is used on the fuel pump. It has a feed from the ECU to power it all up, a return to let the ECU it has done
so, a yellow/red (from memory) to the pump, and a red/white straight from the main fuse to power it all up.
Could it be doing the same thing on your Blade?????
