Thinking about it
posted on 5/4/09 at 08:02 AM |
Punto problem
Yes I know its a Fiat.
My daughter has just reported to me a problem with he r car 1.2 8V Punto Mk2
Starts and runs ok.
No missfires.
No nasty noises.
No power under load up hill or on acceleration.
No smoke
Can't see anything obvious/visual
No engine management light or anything.
Help, this is taking up valuable build time.
[Edited on 5/4/09 by Thinking about it]
eznfrank
posted on 5/4/09 at 08:07 AM |
We have a Cinquecento that had a similar problem when the crank position sensor was on it's way out.
zilspeed
posted on 5/4/09 at 08:23 AM |
Starts and runs ok.
No missfires.
No nasty noises.
No smoke
Maf or throttle pot ?
Thinking about it
posted on 5/4/09 at 08:49 AM |
Zilspeed
I don't understand
Mark Allanson
posted on 5/4/09 at 08:51 AM |
The 2 major weak points of the 1.2 FIRE are the ECU and the head gasket. Always the first things to check.
posted on 5/4/09 at 09:01 AM |
Blocked exhaust/collapsed cat?
davidwag
posted on 5/4/09 at 11:38 AM |
And my crystal ball says " professor plum in the library with the lead piping"
You need to plug it in to get some proper diagnostics done. Even if there are no fault codes logged then you need to look at live data to see whats
going on.
froggy
posted on 5/4/09 at 12:59 PM |
sounds like blocked cat to me ,have a feel at the tail pipe for pressure when you rev it up quite common for a lump to break off and block the
outlet on the cat
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
adithorp
posted on 5/4/09 at 04:42 PM |
Have I missed something? Whats the problem she reported? Or is it just unusual that there's nothing wrong?
adrian
http://jpsc.org.uk/forum/
zilspeed
posted on 5/4/09 at 05:20 PM |
This bit is the problem.
In addition to the points listed above, a duff throttle pot or a dead MAF unit can make the engine go very flat indeed.
Not that they have much grunt to start with anyway...
Thinking about it
posted on 5/4/09 at 05:23 PM |
adithorp
adithorp
posted on 6/4/09 at 12:23 PM |
I that case...
First place I'd be looking is a blocked exhaust. Getting a lot of them this time of year after a damp winter. Condensation rots them inside.
adrian
