Author: Subject: zetec powered dolomite
terryroberts
posted on 5/4/09 at 11:51 AM Reply With Quote
hi guys. not really a kit car..well in bits.. i'm hoping to run zzr1100 carbs on a 1.8 zetec. and make the manifold. what sort of problem will i have.. also how can i run the servo??
cheers terry
posted on 5/4/09 at 11:54 AM Reply With Quote
Have look through my blog, I started with ZZR carbs and changed to ZX9r's for the TPS
Not sure about the servo, maybe using the original injection plate as it connects all the cylinders with a n out put at the flywheel end.
r1_pete
posted on 5/4/09 at 06:33 PM Reply With Quote
Take a look in my archive, I've fitted this configuration in an mgb. Opted for the easy non locost boggs manifold, the servo connection is just in one of the runners.
