MrFozzieBear
posted on 10/4/09 at 08:23 PM |
Stripping Donor
I've just finished stripping my sierra, just wondering if anyone can think of any small items I could easily forget to take,
I got the essentials,
Engine, Gearbox, diff, prop, driveshaft’s, hubs etc,
Handbrake,
Speedo,
Labelled Wiring Loom,
Clocks,
Peddle Box
Wheels,
Front Light Looms.
Any help would be great,
Thanks.
[Edited on 10/4/09 by MrFozzieBear]
Miks15
posted on 10/4/09 at 08:25 PM |
Seats so you can have a sit in the garage with a cuppa reading the manual?
MrFozzieBear
![](/images//smilies/bigsmile.gif)
handyandy
vin plates for id of donor,
steering wheel in case you need a large area for your cockpit dials
cheers
andy
tomgregory2000
posted on 10/4/09 at 08:29 PM |
Hand brake Gator?
MrFozzieBear
posted on 10/4/09 at 08:30 PM |
Excellent thanks for reminding me, i'll make a note and do that first thing.
ReMan
posted on 10/4/09 at 08:39 PM |
steering column
any small bits you can fit in your pockets ![](/images//smilies/wink.gif)
mookaloid
posted on 10/4/09 at 08:45 PM |
I took all the relays etc from under the bonnet but didn't realise that the indicator flasher unit is under the dash near the steering column.
wrigglypig
posted on 10/4/09 at 08:50 PM |
Steering colum cowl
hellbent345
posted on 10/4/09 at 09:01 PM |
haha second that, everyone is after sierra cowls! even if you dont use it its worth more than its weight in myrrh!
RichardK
posted on 10/4/09 at 09:03 PM |
horn,fuel sender from tank,fuel breather valve.
cheers Rich
Gallery updated 11/01/2011
hellbent345
posted on 10/4/09 at 09:08 PM |
oh nips i forgot to take those off mine...
jollygreengiant
posted on 10/4/09 at 09:10 PM |
About 10cm of metal from the fuel tank around (and including) the fuel tank sender hole. This flattens out nicely and can be bolted and seal to your
tank, then you just twist fit the sender unit.
A VERY large bucket/pot with all the screws/nuts/bolts etc that you have removed.
The Brake fluid reservoir cap.
Instrument binnacle.
Slater
posted on 11/4/09 at 07:51 AM |
Steering Wheel
Gear lever
Check the floor under the seats, under the carpet too. You will find coins, I found £2.31 in my donor.
speedyxjs
posted on 11/4/09 at 08:14 AM |
quote: Originally posted by Slater
Steering Wheel
Gear lever
Thats nothing, i found 11 odd quid in mine (although £5 of that had fallen out of my own pocket )
I also took all the nuts, bolts and screws i could get and they have come in quite handy
stevegough
posted on 11/4/09 at 08:17 AM |
Typical scotsman!
£ 2.31 ? I was done - I only got £1.32 out of mine! (and it was in white fivers! ) but it was a very old car!!
engine and gearbox mounts, braking bias valve ( probably better to use this than a bias bar since mr govt. decided they have to be all welded up for
IVA ) ? :
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
MrFozzieBear
posted on 11/4/09 at 08:25 AM |
Yeah i've check for money £1.01p ![](/images//smilies/bigsmile.gif)
snapper
posted on 11/4/09 at 12:13 PM |
Those impossible to find brake hose clips
I eat to survive
I drink to forget
