nib1980
posted on 12/4/09 at 06:18 AM |
Help with welding needed
Hi All
Anyone local fancy welding a sump up for me?
follwing on from this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=110758
I can make the parts ready based on this
http://www.dwjenkins.plus.com/short-sump.htm
I'm just not confident on my welding anymore,?
beer tokens waiting
sorens2
posted on 12/4/09 at 07:52 AM |
Your welcome here but Denmark might not be that local....
Soren S2
t16turbotone
posted on 12/4/09 at 08:08 AM |
hi, have you done ALL the prep work? is it ready to be welded? i may be able to help out
tony
omega0684
posted on 12/4/09 at 08:14 AM |
tony i didn't know you did welding? r u a mig or tig man, or both?
big_wasa
posted on 12/4/09 at 08:16 AM |
Spalding any use.
I have a Tig aswell if you can use it, I cant yet
It would need clamping down to stop it moving when welding.
ashg
posted on 12/4/09 at 08:28 AM |
if you want to post it down to kent i can tig it for you. nice easy little job.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Trev D
posted on 12/4/09 at 08:45 AM |
watcha mate, i'll weld it for you if i am local enough give me a shout if you need me to help. Atb Trev
nib1980
posted on 12/4/09 at 09:05 AM |
HI Trev,
I will probably take you up on your kind offer, I just need to finish the prep work and I can pop over and see you if thats OK.
I fairly sure I've seen you and david going the other way whilst I've been out
I'll drop you a U2U.
Many thanks
Neil
