chrisg
posted on 14/4/09 at 10:12 AM |
Am I a cut and shut?
I'm a worried man.
This morning I was in the shower, lathering up the old clock weights and I found A SEAM!!!!!!
Now I'm worried that I'm two blokes welded together
What do you think?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 14/4/09 at 10:50 AM |
You definitely used to look like two blokes welded together Chris. Turn the water temp up a bit to get them sagging and it might not show up so much.
You might be conjoined twins, it could be your brother in there
edit:- read that through and it's just b0ll0x
[Edited on 14/4/09 by Peteff]
posted on 14/4/09 at 11:00 AM |
The seam is due to cold weather there and disappears as the temp rises.
You can always take a pair of blunt scissors and trim the seam back if it troubles you
chrisg
posted on 14/4/09 at 11:12 AM |
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
I'm going to underseal the area to hide the seam.
Not like you to talk b*ll*cks Pete
Chris
iank
posted on 14/4/09 at 11:44 AM |
An angle grinder with a wire brush will soon rid you of that unsightly seam.
Anonymous
Mr Whippy
posted on 14/4/09 at 11:51 AM |
I explained the 'seam' to missy and what it was and why its there...her mouth nearly hit the floor
Forum decency prevents me explaining it on here
cd.thomson
posted on 14/4/09 at 11:56 AM |
a moderately untidy finish to an otherwise perfect bit of transformational surgery Ms Whippy?
Craig
posted on 14/4/09 at 01:00 PM |
Panic over Chris !
You're normal after all.
But if you really wanted to know why it's there...
That line is Vesling's line. It's a raphe (a ridge) that results from the closure and fusing of the scrotum toward the midline during a
particular phase of fetal development. It marks the position of the septum scroti, a wall of connective tissue inside that separates your scrotum into
two halves, each of which contains a testis.
iank
posted on 14/4/09 at 01:25 PM |
Think this diagram shows the foetal development aspect to which Mr Whippy is alluding.
Probably best not to open it at work.
http://upload.wikimedia.org/wikipedia/commons/d/d6/Gray1119.png
Anonymous
Mr Whippy
posted on 15/4/09 at 01:21 PM |
PMSL ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) errr no
yeah that's it, quite cleaver stuff really
Triton
posted on 16/4/09 at 09:39 PM |
pmsl at this lot........spilt my coffee!!!![](/images//smilies/bigsmile.gif)
www.tritonraceseats.com
www.hairyhedgehog.com
Ninehigh
posted on 18/4/09 at 11:58 PM |
I knew a bloke who was a cut and shut, dead obvious too one half was white and the other half was mexican.
MOT fella at the NHS just failed him on sight...
